Took the written today.. failed!!
"The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net wrote in message ... Failed to get 100 that is!! (gotcha!) Nope! Not a gotcha. I knew better. Except for the 2 questions that were pure bull-shiznit and the vapor lock I encountered on a question that I should have got right had my brain been functioning normally, I would have. Ended up with a 95 - which, coincidentally, was what I was shooting for to be happy with the result. Before you go in to take an FAA test, you should always have taken enough practice tests so that you know within +- 5% what your score is going to be. I am a CFI who happened to take a Private test just two weeks ago. I did not get 100%, and I really would have been surprised to do so, because few tests are 100% accurate. Errors happen, your errors and their errors. You can also mis-click with the mouse and not select the answer you thought you selected. Further, they tend to stick one or two undocumented questions into the pot that they are validating for future use. Congratulations! You did good. Vaughn |
----- Original Message -----
From: "The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net Newsgroups: rec.aviation.rotorcraft Sent: Wednesday, February 16, 2005 10:08 PM Before you go in to take an FAA test, you should always have taken enough practice tests so that you know within +- 5% what your score is going to be. Yeah, I did the practice tests on ipilot.com - probably about 40 times over the past few weeks - and when I nailed 100% on the last 3, I knew I was good to go. The undocumented questions I don't mind.. It's the questions that have 2 answers that could be correct and you need to choose the most correct one that irk me. I don't know ipilot.com, but I have been using http://preparetotest.com/ with good results. Not free, but affordable. Vaughn |
On Fri, 18 Feb 2005 17:33:54 GMT, "Vaughn Simon"
wrote: I don't know ipilot.com, but I have been using http://preparetotest.com/ with good results. Not free, but affordable. ipilot is $29.95 for a year for each rating's practice exams. Definitely worth it in my book. |
Similar Threads | ||||
Instrument Written Test Today | NW_PILOT | Instrument Flight Rules | 11 | January 16th 05 01:20 PM |
Instrument Written Test Today | NW_PILOT | Piloting | 9 | January 16th 05 01:20 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
The Yankee Lady Flew Today | Tom Huxton | Piloting | 0 | July 11th 03 11:57 PM |
The written History of the 344th Bomb Group | ArtKramr | Military Aviation | 1 | July 8th 03 07:05 PM |
