Antares rudder pedal dimensions
Old March 22nd 18, 05:02 AM posted to rec.aviation.soaring
sisu1a
Default Antares rudder pedal dimensions
I'm working on a somewhat generic sailplane cockpit for Condor2, loosely based on the Antares advanced ergonomy. There is a great cross-section of it on their site (below), however I need the actual measurement of at least one component so I can accurately scale the drawing. For this, I've chosen the rudder pedals, because they are the most clearly defined feature that is precisely represented.
http://www.lange-aviation.com/filead...c86ffc0357.jpg
What I need is the center to center distance from the pivot at the heal to the crossbar at the toe. I've emailed Lange for this information, but haven't heard back from them so figured I'd ask here in case anyone (YO Dave?) knows.
Old March 22nd 18, 04:38 PM posted to rec.aviation.soaring
sisu1a
Looks to be very close to 150mm
https://farm1.staticflickr.com/788/4...c6428ddb_o.jpg
Discus Rudder Pedal Adjustment [email protected] Soaring 3 February 26th 16 05:11 PM
rudder pedal springs Dick[_1_] Home Built 6 May 20th 08 07:23 PM
Need Grob 103 Twin II left front rudder pedal Mike McCarron Soaring 1 May 15th 06 02:16 PM
Piper Rudder Pedal Pads Mike Spera Owning 1 November 4th 05 03:31 AM
ASA OnTop 8 Pedal Problem Kevin Instrument Flight Rules 1 August 21st 03 05:42 PM
