Gear Warning
Old November 22nd 05, 01:26 AM posted to rec.aviation.soaring
Default Gear Warning
Mark, the radio check is not transmission check (although announcing
you are in the pattern is always a good idea), it is frequency check (I
often hear pilots calling their pattern on the wrong frequency they
used for air to air), and volume check to make sure your volume is not
down since your last low save. I am very suprised to hear that most
pilots in the UK can not use the radio legally, or am I missing
something?
I agree the list should kept to minmum, but your list has an item which
very much belongs to takeoff checklist, not landing list, unless I
missundersood it: Loose articles (including straps) - I rather
eliminate those *prior* to take off.
Ramy
Old November 22nd 05, 03:27 AM posted to rec.aviation.soaring
Mark Dickson wrote:
At 21:36 20 November 2005, Eric Greenwell wrote:
To ensure they do operate (freezing shut is not the
only way for them to
fail) and to activate the gear warning device.
The radio check may be valid in the States but isn't
necessary in the UK.
Is that because the field frequency is the same as
the one you use
during the flight, or because the glider fields you
use don't use a
radio in the pattern? I'm assuming you'd use the radio
at a regular
airport with mixed traffic.
If you checked your airbrakes at the DI and prior to
take-off, and you have not been flying in icing conditions,
they will open when you want them to. I've never heard
of airbrakes failing in flight and if they did so what?
I had the airbrakes on a Blanik fail to open on the pre-landing checks,
even though they operated correctly before takeoff. The sheet metal lip
caught on the edge of the spoiler box, a problem that didn't show up in
the heat of the afternoon. So, I'm sensitive to this. I agree it's rare.
You'll find out when you unlock them on base leg.
Base leg? I generally don't open them until I turn final. I don't like
opening them on base leg because it makes the turn to final occur at a
lower altitude, and it raises the stall speed. I will open them on the
base leg, or even downwind if it's very important to land as soon as
possible, but not for a normal landing.
As for opening them to activate the gear warner, well
that sounds a bit Irish to me. How about carrying
out the gear part of the checks?
Great idea, which I fully support, but in the first 1500 hours I flew, I
missed it three times due to distractions. I know other pilots that
have also done the same thing, and are pleased they had a gear warner. I
don't know any pilot that is unhappy he installed one. The UK position
was quite a surprise to me. If US pilots routinely landed on grass
fields instead of paved ones, perhaps they would not like gear warners
so much.
The radio is not
a necessary part of pre-landing checks, I and any other
glider pilot in the UK would be very unpopular if they
landed at an airport; and if you were tempted to, the
radio call should be made well before the point at
which the pre-landing checks are carried out. (Most
glider pilots in the UK do not have RT licences and
so couldn't legally make the calls anyway).
This is very different from the situation in the US, where flying from
and landing at public airports is common (mostly non-towered municipal
airports). We are expected to announce our intended landing at the
airport from about 5 miles out, then pattern entry, and typically the
turns to base and final. The frequency is different from the glider
frequency. Doing it on the wrong frequency isn't useful. A license is
not required in the US.
The point I'm trying to make Eric is that for checks
to be effective and not missed, they should only include
those things that are really necessary to check.
Agreed.
The
pre-landing checks I, and a lot of clubs use, are WULF:
waterballast, U/C, loose articles(including straps)
and flaps. In my opinion that is all you need to methodically
check to make a safe approach and landing, anything
else (apart maybe for radio in the States, as you obviously
do land at airports) is superfluous.
I also think these checks should be done prior to joining
the circuit, so that there are no distractions from
carrying them out and so that full concentration can
be given to flying the glider around the pattern and
looking out for other a/c on the ground and in the
air.
Agreed. I typically do them on the 45 degree entry to the downwind leg,
or the crosswind leg.
Eric Greenwell
Washington State
USA
Gear Warning Gadget Guy Soaring 118 November 30th 05 10:43 PM
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 01:59 AM
Gear Warning Switches on a Mosquito scooter Soaring 6 March 9th 05 01:15 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
gear warning plus K.P. Termaat Soaring 0 September 8th 03 08:33 AM
