FYI related to EU/EASA FES Battery Fire AD
Old September 25th 17, 07:16 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
Default FYI related to EU/EASA FES Battery Fire AD
https://www.gov.uk/aaib-reports/aaib...-304-es-g-gsgs
This email has been checked for viruses by AVG.
http://www.avg.com
Old September 27th 17, 10:57 AM posted to rec.aviation.soaring
Presumably the requirement for a fire warning will be followed by additional requirements once the deeper underlying cause has been ascertained. (?)
Old September 27th 17, 06:50 PM posted to rec.aviation.soaring
son_of_flubber
On Wednesday, September 27, 2017 at 1:57:40 AM UTC-4, Ramy wrote:
Sigh, just when we hoped this is is the most reliable sustainer solution.
I wonder if we'll see 'Single Use' FES battery packs based on https://www.amazon.com/DURACELL-Pack...batteries&th=1
Cheaper than landing out.
Old September 27th 17, 07:51 PM posted to rec.aviation.soaring
How well do you think they will handle the 200 amp load?
UH
Old September 27th 17, 08:50 PM posted to rec.aviation.soaring
Renny[_2_]
On Tuesday, September 26, 2017 at 11:57:40 PM UTC-6, Ramy wrote:
Thanks for sharing.
This is not good.
Thankfully in both cases it happened on the ground.
The talks about improving the warning system, as if one can always "land immediately" if fire starts, does not make me feel any better. In fact, it may be better to bail out while high than attempt to land immediately.
Ramy
Ramy,
Keep the faith on the FES. It is an excellent system and is here to stay. I have flown with the FES for 6 years without issue and plan to fly with it for many years to come.
Now, like any system it is crucial that the manuals be read and that all operational procedure be properly followed. If proper procedures are followed and the batteries are properly handled and maintained, then the FES is a safe system and will operate as advertised. Now, we know that the investigation is still on-going so let there be no doubt that whatever recommendations result, will make the FES system even better and safer!
Thanks - Renny
Old September 27th 17, 09:06 PM posted to rec.aviation.soaring
Can't multi post here......:-(
Based on this..... https://d2ei442zrkqy2u.cloudfront.ne...C13US12141.pdf , they only show a max of 3A load for a single cell.
The link from SoF is just a bulk pack of D cells, not a "battery pack". So, to gets amps from 1.5VDC, you wire in parallel, lots of cells can be a lot of amps, but at 1.5VDC.
To get meaningful volts, you wire in series, lots of volts, but at about 3 amps.
To do FES, you need multiple groups. Each group in series to get the volts needed, lots of those to get the amps and runtime.
Sounds like thousands of dollars, lots of weight (alkaline has a low power density vs. weight compared to Lion or LiPo).
Just saying......at SoF............I know HN understands this.
EASA AD on FES battery systems JS[_5_] Soaring 22 October 9th 17 05:14 PM
EASA licence and insurance Andrew Ainslie Soaring 16 March 4th 17 12:58 AM
L-13 STC approved by EASA Frank Whiteley Soaring 0 June 14th 11 10:17 PM
EASA Vs FAA glider[_2_] Soaring 5 December 26th 09 02:38 PM
JPI 800 & GMA 340 into C206 in EASA countries? Jouni Laukkanen Owning 3 August 4th 05 07:30 AM
