Nut/thread securing compound
Eugene Wendland wrote...
Does anyone know what compound is used to secure the nuts and threads on aviation engines? Sounds like you're talking about inspection lacquer. It's not really a securing compound, it just chips and flakes if the material moves. Wicks has it (www.wicksaircraft.com), search for inspection lacquer. Dave 'nut job' Hyde |
aviation engines? I'm not talking about loctite, but the compound that is placed on the outside of the nut and then onto the threads. Usually, it's a very visible colour and laid in a straight line so that one can visually see if a nut or bolt has backed off. It is called Inspector's Anti Sabotage Lacquer or something similar depending on the maker. It does not itself secure the nut or bolt but serves as a witness mark to show whether or not the fastener has backed off. It is required for use on the Cessna oil filter adapter. Most aviation supply outlets carry it even if they don't list it in a catalog. I have on occasion backed nuts off with the lacquer strip not breaking and it will sometimes break and fall off without any lose in torque on the fastener. I've seen it done with silicon, I can't see any advantage to using silicon since it is so flexible the nut could loose torque with silicon simply stetching slightly. |
Nail polish works just as well.
Eugene Wendland wrote: Does anyone know what compound is used to secure the nuts and threads on aviation engines? I'm not talking about loctite, but the compound that is placed on the outside of the nut and then onto the threads. Usually, it's a very visible colour and laid in a straight line so that one can visually see if a nut or bolt has backed off. I've seen it done with silicon, but I'm wondering what the real hard compound is. Any suggestions? Thanks Gene |
Date: 4/20/2004 7:10 PM Central Daylight Time Message-id: Nail polish works just as well. White nail polish makes an excellent slippage mark for indicator coverglasses where range marks are required. We used it in the USAF along with clear nail polish to extend the life of the rangemarks themselves. Dan, U.S. Air Force, retired |
A/C Spruce has it on page 323 called: "Torque Seal". or "Skydrol". Both
are called inspection lacquers. In the past we used a yellow 3M weatherstrip adhesive on racing dirt bikes. It actually holds the nut to the bolt and not just a movement indicator. Stu Fields Safari driver "Eugene Wendland" wrote in message ... Does anyone know what compound is used to secure the nuts and threads on aviation engines? I'm not talking about loctite, but the compound that is placed on the outside of the nut and then onto the threads. Usually, it's a very visible colour and laid in a straight line so that one can visually see if a nut or bolt has backed off. I've seen it done with silicon, but I'm wondering what the real hard compound is. Any suggestions? Thanks Gene |
... Does anyone know what compound is used to secure the nuts and threads on aviation engines? I'm not talking about loctite, but the compound that is placed on the outside of the nut and then onto the threads. Usually, it's a very visible colour and laid in a straight line so that one can visually see if a nut or bolt has backed off. I've seen it done with silicon, but I'm wondering what the real hard compound is. Any suggestions? Here's one for the "Don't try this at home" file. Years ago (when Eisenhower was Pres.) I worked in the shipyards as a pipefitter. I forget why, but occasionally we would seal pipe threads with a creamy mixture of Litharge and Glycerine. It would harden into a white substance with excellent sealing properties. There was a setup table in the shop made from granite. One day a forklift got too close and busted off a corner of the table. Somebody got the idea to glue it back on with the Litharge/Glycerine goo. Worked good. Sometime after I left the trade, I'm told that a fitter was pounding on a piece of steel which was lying on the broken seam. Now, I won't swear to this, 'cuz I didn't see it, but it seems the mix had turned into nitroglycerine and blew up. So, think twice about where you're hammering! ) Rich S. |
Similar Threads | ||||
Somebody Terrified of Compound Curves ---- Or Just Lazy | Larry Smith | Home Built | 8 | October 31st 03 02:40 PM |
