#11
In Flight Emergency
I think a more likely scenario in which a tug pilot might wish he had
a parachute would be after a midair collision rather than an engine failure. At 16:55 17 March 2015, Dan Marotta wrote: Yes, and I wear a chute when I fly my glider, but not when I'm giving rides in a Grob, Blanik, 2-33, or Lark. Neither do I wear a parachute when flying the tug and I've had four engine failures while flying tow planes, in none of which would I have considered bailing out. Does Poland really require parachutes in gliders? Are passengers with no training required to wear a parachute? I wonder about the outcome if one of them should attempt to jump. On 3/17/2015 9:57 AM, Luke Szczepaniak wrote: In some countries parachutes are mandatory in gliders (for instance Poland where the OP is from). In North America they are not mandatory. Most private owners, at least those I am exposed to, choose to wear one. Most pilots flying club single seaters at my club wear one. Most instructional flights are done done with out parachutes. Acrobatic flights as well as standard spin training is done with parachutes. Luke On 03/17/2015 11:43 AM, Dan Marotta wrote: What do you need a chute for? Most tow pilots are also glider pilots and fully capable of landing an airplane without the engine running. It would be pretty weak to jump out of a perfectly good airplane just because the engine stopped which, in this case, it didn't until the pilot shut it down. On 3/17/2015 6:53 AM, Luke Szczepaniak wrote: On 03/16/2015 6:57 PM, wrote: No chute? Not required? S Not required in USA or Canada by law. Parachutes required in competitions by the rules. -- Dan Marotta -- Dan Marotta |
In Flight Emergency
Does Poland really require parachutes in gliders? Are passengers with no training required to wear a parachute? I wonder about the outcome if one of them should attempt to jump. See https://youtu.be/dDhl5dOd4_0. It might make you think again |
In Flight Emergency
In Flight Emergency
In the UK I think we insist on first flight pupils wear a parachute,as to
whether they can use them. When a first flight was hit by lightning they both had a first parachute experiences ,and it was the instructor that broke his leg. At 16:55 17 March 2015, Dan Marotta wrote: Yes, and I wear a chute when I fly my glider, but not when I'm giving rides in a Grob, Blanik, 2-33, or Lark. Neither do I wear a parachute when flying the tug and I've had four engine failures while flying tow planes, in none of which would I have considered bailing out. Does Poland really require parachutes in gliders? Are passengers with no training required to wear a parachute? I wonder about the outcome if one of them should attempt to jump. On 3/17/2015 9:57 AM, Luke Szczepaniak wrote: In some countries parachutes are mandatory in gliders (for instance Poland where the OP is from). In North America they are not mandatory. Most private owners, at least those I am exposed to, choose to wear one. Most pilots flying club single seaters at my club wear one. Most instructional flights are done done with out parachutes. Acrobatic flights as well as standard spin training is done with parachutes. Luke On 03/17/2015 11:43 AM, Dan Marotta wrote: What do you need a chute for? Most tow pilots are also glider pilots and fully capable of landing an airplane without the engine running. It would be pretty weak to jump out of a perfectly good airplane just because the engine stopped which, in this case, it didn't until the pilot shut it down. On 3/17/2015 6:53 AM, Luke Szczepaniak wrote: On 03/16/2015 6:57 PM, wrote: No chute? Not required? S Not required in USA or Canada by law. Parachutes required in competitions by the rules. -- Dan Marotta -- Dan Marotta |
In Flight Emergency
On Tuesday, March 17, 2015 at 12:45:05 PM UTC-5, John Galloway wrote:
I think a more likely scenario in which a tug pilot might wish he had a parachute would be after a midair collision rather than an engine failure. Or an inflight engine fire. Falls "loosely" into "engine failure". But, I know what you are talking about John. As a friend once said, "The only time there is too much fuel onboard is when the plane is on fire." Steve Leonard |
In Flight Emergency
Not really...
Thanks for posting that, though. After filtering through the standard broadcast TV BS, it made a really interesting story. Glad they came out of it OK. I would question taking passengers under a thunder storm. Isn't that like poking a bear? Have I done that? Sure. Have I done it with a passenger? No f**king way! And yes, I still wear my parachute when I fly my glider. And it's a ram air canopy just like shown in the video. Do you really use those in gliders on the east side of the Atlantic? On 3/17/2015 12:05 PM, Mike Oliver wrote: At 16:55 17 March 2015, Dan Marotta wrote: Does Poland really require parachutes in gliders? Are passengers with no training required to wear a parachute? I wonder about the outcome if one of them should attempt to jump. See https://youtu.be/dDhl5dOd4_0. It might make you think again -- Dan Marotta |
In Flight Emergency
Yes it really happened about 12 years back, and the pupil came back for a
second flight exactly 10 years after. From memory they thought they were well clear of a dark cloud that then sent a horizontal charge out that hit the wing tip. Ask21 and the wholè front of the cockpit blew off so using the parachute was a bit of a no brainier really . One of them landed on a filling station cannopy and they had to get a ladder to get him down. At 19:09 17 March 2015, Dan Marotta wrote: Not really... Thanks for posting that, though. After filtering through the standard broadcast TV BS, it made a really interesting story. Glad they came out of it OK. I would question taking passengers under a thunder storm. Isn't that like poking a bear? Have I done that? Sure. Have I done it with a passenger? No f**king way! And yes, I still wear my parachute when I fly my glider. And it's a ram air canopy just like shown in the video. Do you really use those in gliders on the east side of the Atlantic? On 3/17/2015 12:05 PM, Mike Oliver wrote: At 16:55 17 March 2015, Dan Marotta wrote: Does Poland really require parachutes in gliders? Are passengers with no training required to wear a parachute? I wonder about the outcome if one of them should attempt to jump. See https://youtu.be/dDhl5dOd4_0. It might make you think again -- Dan Marotta |
In Flight Emergency
Try this
www.youtube.com/watch?v=dDhl5dOd4_0 At 19:09 17 March 2015, Dan Marotta wrote: Not really... Thanks for posting that, though. After filtering through the standard broadcast TV BS, it made a really interesting story. Glad they came out of it OK. I would question taking passengers under a thunder storm. Isn't that like poking a bear? Have I done that? Sure. Have I done it with a passenger? No f**king way! And yes, I still wear my parachute when I fly my glider. And it's a ram air canopy just like shown in the video. Do you really use those in gliders on the east side of the Atlantic? On 3/17/2015 12:05 PM, Mike Oliver wrote: At 16:55 17 March 2015, Dan Marotta wrote: Does Poland really require parachutes in gliders? Are passengers with no training required to wear a parachute? I wonder about the outcome if one of them should attempt to jump. See https://youtu.be/dDhl5dOd4_0. It might make you think again -- Dan Marotta |
In Flight Emergency
On Tue, 17 Mar 2015 13:09:44 -0600, Dan Marotta wrote:
I would question taking passengers under a thunder storm. Isn't that like poking a bear? Have I done that? Sure. Have I done it with a passenger? No f**king way! Although thunderstorm activity was forecast for the day, nobody knew the cunim that struck the glider was the it was hidden inside a surrounding bank of cloud and the glider was flying away from the side of the surrounding cloud when it was hit by the first lightning strike emitted by that cunim. The full AIB report is he http://www.pas.rochester.edu/~cline/...%20strike/ASK% 20accident%20report.htm It makes interesting reading: By the time I joined a gliding club and started learning to fly in 2000, almost exactly a year after that lightning strike, nobody flew or was flown at my club without a parachute, a discipline that we still follow. I've always heard that is a direct result of the accident. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
In Flight Emergency
The AIB's comments regarding composite gliders are interesting: "In addition, this accident highlights the inadvisability of flying unprotected composite aircraft in close proximity to thunderstorms and the prudence of wearing parachutes in such composite gliders."
However, I know of no other lightning/glider incidents in which the use of a parachute was needed. Mike (who routinely flies closer to thunderstorms than advised!) |
Similar Threads | ||||
First emergency | EventHorizon | Owning | 14 | February 3rd 10 05:40 PM |
Emergency Procedures | Mitty | Instrument Flight Rules | 30 | July 18th 06 03:25 PM |
Emergency | Dan Luke | Piloting | 57 | April 12th 06 02:01 PM |
JetBlue Flight Approaches For Emergency Landing At LAX | Larry Dighera | Piloting | 5 | September 23rd 05 05:01 AM |
Not an emergency??? | William W. Plummer | Instrument Flight Rules | 14 | December 26th 03 06:28 AM |
