#51
When to descend II
Bee wrote: But, I don't know all those controller rules. Is that in the AIM anywhere? If not, I would exercise my PIC option to seek clarification. By all means ask if you're unsure. But it's still not necessary. Just like an approach clearance cancels a speed restriction unless restated or a descend and maintain clearance cancels a pilot discretion descent. |
#52
When to descend II
"Dan Luke" wrote in message ... You're 4 miles SW of ROYCE. http://www.naco.faa.gov/d-tpp/0710/00198IL12R.PDF Approach says "Cessna '1GS,cross ROYCE at or above 2 thousand, cleared visual approach runwy 12R. Contact the tower on 118.7." On initial contact, Tower says "Cessna '1GS, runwy 12R, cleared to land." Do you still have to cross ROYCE at 2,000 or can you head for the numbers and come on down? Head for the numbers and come on down. |
#53
When to descend II
"john smith" wrote in message ... If you are going to fly the ILS, yes. If you are going to request a visual approach, no. Visual approach clearance has been issued. |
#54
When to descend II
"Peter R." wrote in message ... Not enough information. Were you tracking the ILS when the visual approach was issued? Or were you approaching the airport from another direction? The position was given as 4 miles southwest of ROYCE. |
#55
When to descend II
"Bee" wrote in message ... I presume approach had vectored you onto the localizer previously or you would not be able to identify ROYCE. The position was given as four miles southwest of ROYCE. The instruction to cross ROYCE at or above two-thousand is an IFR restriction with which you must comply because the visual approach isn't authorized until passing ROYCE. The visual approach is authorized the instant it's issued. |
#56
When to descend II
"Ron Rosenfeld" wrote in message ... I've not flown in that area, but ATC may be wanting you to fly to Royce before turning inbound because of traffic on approach to Rwy 12L. There are some issues with intersecting flight paths that need to be avoided when dealing with parallel runway operations. If ATC wants him over ROYCE they must issue routing over ROYCE or vector him to that point and withold visual approach clearance until he's over ROYCE or past it. Of course, if in VMC, you could cancel your IFR flight plan, mooting the previous ATC clearance. Well, he can cancel, but that may not do a lot for him. It's Class B airspace so separation is still an issue. |
#57
When to descend II
"Newps" wrote in message ... An at or above altitude in a clearance like that almost always means there will be traffic under you going into a different airport. Hard to fit another airplane between traffic at 2000 MSL and towers over 1000 MSL. |
#58
When to descend II
"Bee" wrote in message ... No turn inbound required. He is presumably already on the localizer or he couldn't identify ROYCE. No presumption required, it was given that he's four miles southwest of ROYCE. Might not be the best airspace to be doing that without making sure you won't be descending onto some other aircraft like Newps says. There's no room for traffic below. |
#59
When to descend II
"Bee" wrote in message ... But, in essence you are clearing me direct-to-the-FAF. This is not an en route fix or even an IAF or earlier. Only in limited circumstances are you allowed to clear me direct to an RNAV IF. I certainly don't see how you can make me cross a FAF unless you have correctly placed me on the IAP. It's easy. "Cessna 1GS, proceed direct ROYCE, expect visual approach runway 12R." |
#60
When to descend II
"Bee" wrote in message ... Okay, I get it. The IAP is not even in the plan. IFR to a fix, then visual or, if unable, a new plan. Maybe, the at or above 2,000 at ROYCE was to keep the pilot at MVA instead of for traffic? You think maybe so? The MVA is irrelevant once cleared for the visual approach. |
Similar Threads | ||||
When to descend | Dan Luke[_2_] | Instrument Flight Rules | 44 | October 14th 07 09:12 AM |
