A-7D/E Question (was Why no armor for soldiers ?)
Old October 8th 03, 05:52 AM
redc1c4
Default A-7D/E Question (was Why no armor for soldiers ?)
Daryl Hunt wrote:
"redc1c4" wrote in message
Daryl Hunt wrote:
(snipage occurs, fore and aft)
But one has to understand that an A-7 could pick it's own weight up
in ordinance. Empty weight for the A-7E was just over 15,000 lbs
including fuel. Loaded, it was a bit over 30K. If you could sling
it under it, it could lift it. The D and E models (AF and Navy)
were are remarkable Aircraft for it's size. And it carried two
Aim9s as well.
funny, that's not what it says at the Vought web site, but hey,
they only built them, what would they know?
http://www.voughtaircraft.com/
Well, Troll. Since you have no idea how they were actually used, you are
just trolling. Now go back to playing with your little plastic soldiers.
neither you, nor anyone else, can eliminate the laws of physics.
the manufacturer states what the empty, max, and fuel weights were for
the plane. they don't add up to your numbers.
either you, or Vought and the Air Force, are lying. i'll let others
decide which is which on their own
redc1c4,
what say the residents of RAM; is he talking out his ass again?
A Troop - 1st Squadron
404th Lemming Armored Cavalry
"Velox et Capillatus!"
Old October 8th 03, 12:09 PM
Thomas Schoene
redc1c4,
In 1982, Jane's had the following figures for the A-7E:
Empty Weight: 19,127 lbs
Max T-O Weight: 42,000 lbs
That's a difference of 22,837lbs, so potential payload did exceed the empty
weight of the aircraft. But that's including pilot, consumables, fuel, and
weapons (including pylons). The maximum external weapon load was stated as
15,000 lbs. That was carried on six underwnig hardpoints (four @ 3500 lbs,
two @ 25000 lbs) and twio fuselage stations @ 500 lbs (for AAMs). Yes, that
adds to 20,000 lbs, but you could not safely load all the stations to their
maximum stressed weights.
Whether that's a realistic load for operational use is of course a different
issue.
Tom Schoene Replace "invalid" with "net" to e-mail
"If brave men and women never died, there would be nothing
special about bravery." -- Andy Rooney (attributed)
Old October 8th 03, 07:01 PM
John Carrier
The A-7's empty weight was a bit over 20K IIRC, certainly not 15 (even in
the A-7A version ... the E was much heavier). The A-7 never lifted its
empty weight in stores. That would have taken it well over max gross.
R / John
Aim9s as well.
are
soldiers.
redc1c4,
Old October 8th 03, 08:57 PM
Guy Alcala
Dorr's book lists the A-7A @ 15,037 lb. empty, MTOW 32,500 lb. A-7D is listed
at 19,781 lb. empty, 42,000 lb. MTOW, essentially agreeing with Tom's data from
Jane's. Typical bombload during Vietnam for Navy A-7s was about 6,000 lb.,
although during DS they tended to operate with only 4,000 lb. such as 4 x Mk.
83 1,000 lb. bombs (plus an AIM-9 or two), as they'd removed two pylons to
decrease the drag. USAF A-7Ds tended to operate with 4-6,000 lb. in Vietnam,
plus two tanks and a pod or two if going into a high-threat area. Navy a-87s
in Vietnam tended not to carry tanks (they were closer to the targets) unless
they were acting as buddy tankers, and they had internal ECM so didn't need to
take up a pylon or two with that.
Guy
Old October 9th 03, 03:05 AM
Daryl Hunt
"Guy Alcala" wrote in message
in
listed
from
lb.,
Mk.
Vietnam,
a-87s
unless
need to
The army pukes think they know what things really are but in the end, they
don't know jack. Followed the Sluf for at least a decade. It was sad to
see it fly into Chanute one last time for a Static Display.
Old October 10th 03, 12:59 AM
John Carrier
From the former operators whom I work with every day. A-7B 19,500 empty,
A-7E 21.500 empty. Typical bomb load off 27C was 8 or 10 Mk82 (depending on
wind ... the cats were short). Otherwise 10-12 Mk82. Preferred was 4-6
Mk83 on the parent racks (no MERs/TERs with weight and drag), rare for the
Navy in Viet Nam. Add 400# for two sidewinders (given the ACM capability of
the SLUF, they would have proven more effective mounted backwards). Tanker
typically 2x300Gal drop + D704 = 6000+ lbs. It would appear that your 6K,
give or take, is the typical operational load.
None of those I talked with (two of with combat experience) thought a field
T/O at max gross of 42K was practical unless the concrete was REAL long and
the day was REAL cold. I don't think A-7D's were launching in SEA at max
gross given the typical wx etc. The airplane was a real pig at 38K or over.
in
listed
from
lb.,
Mk.
Vietnam,
a-87s
unless
need to
Guy
Old October 10th 03, 01:56 AM
Daryl Hunt
"John Carrier" wrote in message
news
on
of
Tanker
field
and
over.
There is always restrictions on Carrier AC that are not on concrete jumpers.
Old October 10th 03, 07:24 PM
John Carrier
jumpers.
There are conditions when T/O weight and wind + density altitude conspire to
make a very long stretch of concrete seem very short. As the A-7 was not
endowed with prodigious quantities of thrust, a heavy takeoff on a hot day
could be thrilling. Throw in a few thousand feet of field elevation and
you'd best enter your T/O tables in the big thick book.
Max gross is often a structural or wt/balance consideration w/o regard for
T/O issues. I was fortunate to never fly an aircraft that was relatively
underpowered ... a heavy A-7 was.
R / John
Old October 13th 03, 12:31 AM
TJ
"Daryl Hunt" wrote in message
news
empty,
(depending
on
capability
of
Tanker
6K,
field
and
max
over.
jumpers.
Guys,
Daryl Hunt is also known as "Dead Meat". Do a search on google groups for
Daryl Hunt or Dead Meat and you'll see the type of nut job that you are
trying to debate with. Don't debate with him and let him get back to finding
his medication.
Some examples of his work:
"Groom lake still has a squadron of the YF-12s. I have no idea why they are
still there and why the get preflighted. I don't even know who actually
controls them. Yet, as of 1991, they were still there. The difference
between the A-12 and YF-12 was the mission. the A-12 was a ground attack
Nuclear Fast Attack (fast ain't even the word here) ....
Whereas, for about a decade, the SR had a mission until it was nuetralized
by a 3 stage SA
missile."
"No, the FB-4 was in the 30s but the Air Force had three designated in
Incirlik Turkey as Strategic Bombers. The FB-111 was not quite online.
When it came online, the FB-4 no longer carried that designator. Are there
pictures of the FB-4 Nuke Carriers? No, they confiscated film frome the
cameras from anyone that anyone came within vision with. Would they be in
the Internet? I doubt it. It's like saying the original C-130 from 1953 is
in original condition as it claims at Wright Pat as it sits with a 1957
radome, 4 AC generators on the Engines and the Gun Mounts under the Carpet.
I remember it as a Spectre Gunship. Yup, history has a tendancy to be
rewritten. When some of us are long gone, there will be no more
recollection of any of this and history will be changed forever once again
with the passing of time."
.........(ON KAL007)
"Okay, since you can't do the story on this one, let me
hit you with the real story, youngster. Not the official one that was put
out to save the Soviet Militaries face and avoid a war. BTW, this happens
more than you will ever know.
The US keeps a geo sat above the Kamchuka Penninsula at
all times. We lost the Sat. During the lag time to get another one in
place, the US had to rely on Aircraft to bridge the gap. YOU, the Soviets
introduced a new 100k+ AM that could knock out the SR-71 so the SR could
only
do a side shoot in inernational waters. We were launching a RC-135 and a
EC-135 to get pictures at very close range. The RC was a Camera Ship
while the EC provided Cover from international Air Space. The EC
operated while the RC was making the camera run. Those two put your defense
fighters on edge. The EC would come in after a routine flight while the
RC came in with cooked engines from running in Mil Power for too long a
time.
The RC carried the same engines that a C-141 Carried so it was more than
just a bit overpowered by that days standards. Ever fly an AC right at Mach
running very close to Zero altitude? When speed and atlitude won't work,
you
bring lots of Gas with you. Fighters can only run for a few minutes at
this type of speed near sea level whereas the Tanker can run much longer.
This means the Tanker is relatively safe if you don't mind riding the
worlds most hairy Carny ride in the World. Heat Seekers can't touch it,
the EC keeps the Radar Missiles at bay and if you use your guns at that
speed, you will fly into your own bullets. A complete NDI of the RC plus
all 4 engine changeout on return was considered a routine mission. This
mission didn't last very long as a new Sat was readied and launched to
replace
the malfunctioned Sat. During this time, the KAL was shot down by an over
zealous pilot. Never did understand why since these types of games were
played
by both sides on a daily basis in that part of the world. Your T-95 Bear
was very good at it also. None of this was ever done "Officially" by
either side."
TJ
Old October 10th 03, 04:09 AM
Guy Alcala
A-7E 21.500 empty.
Is that empty, which Jane's and Dorr gives, or (more likely) OWE (i.e. ready to
fly in combat, less fuel, ammo, and payload)?
Yes, agrees with contemporary photos. There weren't many SCB-27C/A-7 cruises,
but there were a few.
Preferred was 4-6
The A-7D with auto-maneuvering flaps wasn't that bad with just parent racks,
according to a friend who flew them in the ANG as well as A-7Es in the navy.
Not in the F-16's league, which he later flew, but he had claimed both F-4 and
(Japanese) F-15 'kills' in the A-7D when the pilots did dumb things. Besides, a
successful AIM-9 shot in Vietnam was usually on someone who didn't see you
coming, or who'd lost sight, and at least the A-7s had a means of discouraging
head-on cannon attacks.
4 x Mk. 83s (or other) on parent racks was fairly common in DS. They'd pulled
an inboard pylon (IIRR) on one side and the intermediate pylon on the other side
to slick them up. I forget the reason for the assymetry, but it probably had
something to do with allowable loads.
Tanker
Entirely reasonable comments.
Guy
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
