Winter Mech Vario Bezel
I want to mount a Winter mechanical vario in my glider.
It has a bezel ring around the face that is wider than the standard 3 1/8' diameter of the face. Anyone have a clue as to how to remove the bezel, so the instrument can be mounted to the panel? I don't see any obvious keys/slots/or breaks in the ring? Mike |
If it's the Macready ring you're talking about - you just pop it off. It
snaps into place and snaps off as well. Jim "Mike Hostage" wrote in message ... I want to mount a Winter mechanical vario in my glider. It has a bezel ring around the face that is wider than the standard 3 1/8' diameter of the face. Anyone have a clue as to how to remove the bezel, so the instrument can be mounted to the panel? I don't see any obvious keys/slots/or breaks in the ring? Mike |
I believe the bezel is held in place by 3 spring loaded balls that fit
within a groove on the inside lip of the instrument. You can't see them with the bezel in place. To remove the bezel, simply pull it forward away from the instrument. bumper "Mike Hostage" wrote in message ... I want to mount a Winter mechanical vario in my glider. It has a bezel ring around the face that is wider than the standard 3 1/8' diameter of the face. Anyone have a clue as to how to remove the bezel, so the instrument can be mounted to the panel? I don't see any obvious keys/slots/or breaks in the ring? Mike |
Similar Threads | ||||
[For Sale] Winter Vario | Ludovic Launer | Soaring | 0 | March 21st 05 08:40 AM |
Winter Flying | [email protected] | Piloting | 36 | January 3rd 05 03:19 AM |
WTB: McCreedy speed ring | Slick | Soaring | 7 | July 16th 04 03:11 AM |
WTB: (USA) Mech Vario 57mm(2-1/4) Knots | Curtl33 | Soaring | 7 | January 24th 04 03:31 AM |
Vario time constants | Bill Daniels | Soaring | 3 | January 20th 04 03:18 PM |
