Follow up on fuel drains
Old August 16th 03, 05:01 AM
Mike Noel
Default Follow up on fuel drains
The Curtis valve fuel drains from Aircraft Spruce were about $10 each
including shipping, they are TSO'ed and come with some kind of sealant at
the base of the thread grooves. They also still have 'O' rings, but the
manufacturer says to replace the entire valve and not to 'overhaul' the
valve. They were very easy to replace with a 7/16 inch wrench (on the
Archer.)
Regards,
Mike
Old August 27th 03, 01:23 PM
JDupre5762
Archer.)
The Curtis valve does not use an O'ring. At least it is not a traditional
circular cross section O'ring. The cross section of the Curtis seal is more
flat or oval shaped. Many people use standard O'rings to replace this seal and
they will fail sooner rather than later. It is difficult to find the proper
number in a typical aircraft parts book and many people never knew about the
difference in the design of the seals.
Some years ago Curtis stopped selling replacement seals preferring to sell
entire drains instead. Apparently they think this is better than educating the
flying and maintaining public about the use of the proper seal. So instead of
spending pennies to reseal a drain now you have to spend $10.
I would like to know if anyone else sells a suitable seal of the appropriate
style for use on the Curtis drain?
John Dupre'
Old August 27th 03, 01:51 PM
Justin Case
I think Curtis will still sell the funny O rings to mechanics. You
may want to check with your guy to see. FWIW I'm getting the Curtis
valves for $7 through TexAir in Ft. Worth.
Archer.)
John Dupre'
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Declared "minimum fuel" O. Sami Saydjari Instrument Flight Rules 14 April 4th 04 02:43 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 07:35 AM
