Cherokee shoulder seat belt replacement
"Morgans" wrote in message ... .. a dremel to cut the head off... Sometimes it is possible to use a little cutoff wheel in a Dremel to cut a slot right across a Philips screw head and then use a flat screwdriver. Vaughn |
"Vaughn Simon" wrote in message ... "Morgans" wrote in message ... .. a dremel to cut the head off... Sometimes it is possible to use a little cutoff wheel in a Dremel to cut a slot right across a Philips screw head and then use a flat screwdriver. Done that many times with good results. I didn't mention it, because he said he had problems fitting a screw driver into the screw, because stuff was in the way. I didn't think that a flat would work any better than the Phillips. Really, I have found that a flat will not usually work as well, when the shaft can not be held in straight alignment with the screw. YMMV. -- Jim in NC |
On Sep 25, 9:08*pm, "Morgans" wrote:
"Vaughn Simon" wrote in message ... "Morgans" wrote in message ... .. a dremel to cut the head off... * Sometimes it is possible to use a little cutoff wheel in a Dremel to cut a slot right across a Philips screw head and then use a flat screwdriver. |
wrote Kinda makes one wonder how the factory gets the screws in the first time... G Ain't that the truth! I have two possible answers. The assembly was built up in a way that it can not be taken apart in reverse order, or there was some damn special tool involved. Perhaps a screwdriver tip made real close onto a universal joint. In my way of thinking, if it requires a special tool, 99% of the time it was poor engineering that makes the special tool necessary. -- Jim in NC |
Can you take a photo of the device and post it to
alt.binaries.pictures.aviation -- or somewhere else, or email it to me? |
"Jon Woellhaf" writes:
Can you take a photo of the device and post it to alt.binaries.pictures.aviation -- or somewhere else, or email it to me? Upload to sendspace.com; then post the URL.... I can't see how 3 tiny screws secure it.... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
"Jon Woellhaf" wrote in message . .. Can you take a photo of the device and post it to alt.binaries.pictures.aviation -- or somewhere else, or email it to me? That should be asked of Texas Slacker, I believe. -- Jim in NC |
Neither in this case..
Simple, good engineering.. The head is on the OUTSIDE OF THE FUSELAGE , on the roof. You need someone on the outside , standing on the wing walk,holding the headwhile you twist off the AN nut on the inside. Not everyone quickly makes the connection between the bold head on the roof with the seat belt assy on the inside.. One of the many features that make Mr. Piper's airplanes so easy to work on.. Dave On Fri, 26 Sep 2008 18:10:34 -0400, "Morgans" wrote: wrote Kinda makes one wonder how the factory gets the screws in the first time... G Ain't that the truth! I have two possible answers. The assembly was built up in a way that it can not be taken apart in reverse order, or there was some damn special tool involved. Perhaps a screwdriver tip made real close onto a universal joint. In my way of thinking, if it requires a special tool, 99% of the time it was poor engineering that makes the special tool necessary. |
I don't know how Piper does it, but Cessna puts that screw in place and then
builds the airplane around it. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle Kinda makes one wonder how the factory gets the screws in the first time... G |
Similar Threads | ||||
Seat belt clip | Fred[_4_] | Soaring | 2 | June 23rd 08 05:10 PM |
Seat Belt should be re-webbed or changed | Patti Browne | Soaring | 3 | December 13th 06 04:10 AM |
Seat belt tags | Stephen Stilkey | Owning | 28 | March 15th 04 04:29 PM |
Seat Belt Extenders | M.E. Borner | Owning | 4 | October 3rd 03 01:55 PM |
Seat Belt Age? | BD5ER | Home Built | 2 | July 7th 03 12:10 AM |
