PowerFLARM Tips Update
Hi,
Is your PowerFLARM "IGC Enabled"? Tonight I updated my PowerFLARM Tips document with helpful information about the "IGC Enable" option in PowerFLARM Units. http://www.cumulus-soaring.com/flarm...FLARM-Tips.pdf Good Soaring, Paul Remde Cumulus Soaring, Inc. |
Thanks of the tips above.
Is there a way to copy From the Power Flarm the config file that is in it already, to check the settings? Kevin 92 |
On Tuesday, June 21, 2016 at 11:08:17 AM UTC-4, wrote:
Thanks of the tips above. Is there a way to copy From the Power Flarm the config file that is in it already, to check the settings? Kevin 92 Most is in the header of your IGC file. Download it and open with a text editor (Textedit, Notepad). It's before the B records start.... |
Thanks
Kevin 92 |
Similar Threads | ||||
PowerFlarm Update Problem | John Carlyle | Soaring | 14 | April 15th 15 11:20 PM |
PowerFLARM Portable Firmware Update: 6.02 | Paul Remde | Soaring | 15 | April 10th 15 03:13 PM |
PowerFlarm Update? | Mike the Strike | Soaring | 71 | March 21st 15 05:32 PM |
Portable PowerFlarm hardware update | kd6veb | Soaring | 8 | March 22nd 13 10:44 PM |
PowerFLARM Display Update | Paul Remde | Soaring | 2 | November 11th 10 06:40 PM |
