OLC "Advanced" flight information
Old May 11th 17, 04:07 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default OLC "Advanced" flight information
I see a tab on the OLC Plus, beside "Standard", for "Advanced" information. There is no indication of what that is, or why it would be worth subscribing (The Canadian Soaring Association already pays $1000CAD/yr to OLC). Does anyone have a screen shot of what that looks like, or a link that describes what value added it might provide?
Thank you in advance.
Dan
Old May 11th 17, 04:16 PM posted to rec.aviation.soaring
Alex[_6_]
Advanced is just a different map view similar to the google-maps option which also requires a login. Both options are available after logging in. There is no subscription fee.
The OLC does invite you to donate - but the only advantage is a smiley beside the claimed flights. To my knowledge the donation is purly voluntary and does not come with any special features.
Old May 11th 17, 04:48 PM posted to rec.aviation.soaring
Duster
I believe the "advanced" view requires not only an account login, but also a small donation to OLC. The Google view requires login only and there are a limited number of times per day you can view flights.
Old May 11th 17, 05:10 PM posted to rec.aviation.soaring
Just logged into OLC (I'm also a donor) and clicked on 'advanced' for one of today's flights. Wow, it opens a large relief map of the flight area, the entire path, barogram and scored turn points. As for the Standard map, the flight path can be followed by sliding the mouse pointer along the barogram. Map view can be changed to Satellite.
Old May 11th 17, 05:37 PM posted to rec.aviation.soaring
JS
There is not a fee for Google Maps. There is a fee for Advanced.
What can a PNA do better because it has information from flight instruments? son_of_flubber Soaring 6 January 7th 13 11:23 PM
Raptors are the worlds most advanced ground display "aircraft" Dan[_15_] Piloting 2 October 24th 11 01:02 AM
AIR FRANCE FLIGHT AF 447 Media Information [email protected] General Aviation 0 June 8th 09 10:12 PM
Col. Robert Bowman, PhD, U.S. Air Force (ret) - Director of Advanced Space Programs Development under Presidents Ford and Carter. "A lot of these pieces of information, taken together, prove that the official story, the official conspiracy theor Custard Cream Naval Aviation 10 July 14th 07 06:51 PM
getting "all available information" before flight Robert M. Gary Piloting 14 June 15th 06 04:23 PM
