Can I fly it at night?
I have a 1941 Chief with lights on it. There's one light on
each wingtip and one on the top of the fin. There's no anticollision light/strobe or landing light. There are wires from the 3 position lights to the cockpit, where they end. The engine has no alternator or generator and never has had one. There's no battery, battery compartment, starter or electrical system. I do have a portable sealed lead acid battery that I charge between flights to power a radio and intercom. There's nothing in the paperwork about "day VFR only" and there's no AFM or even any POH. I've looked at 91.209 and 91.205 (c). I've got position lights, I won't be operating for hire, so I suppose a landing light is not legally required. I suppose a larger battery would be an adequate source of electrical energy for short flights. Can I fly at night if I install an anticollision light? Anyone want to comment on what I need to legally fly at night for short local flights? Does anyone think the disconnected lights have made the aircraft legally unairworthy for the last 65 years? Does anyone know how these were originally powered (Dry cells?) Thanks for any information. |
On 4 Jan 2006 09:06:03 -0600, bstanton null.com wrote in
:: I have a 1941 Chief with lights on it. [...] Does anyone know how these were originally powered (Dry cells?) Thanks for any information. The information should be in the aircraft's Type Certificate. You should be able to find it he http://www.airweb.faa.gov/Regulatory...e?OpenFrameSet |
In this case the type certificate doesn't make a difference. The FAA
current FARs seem to require a strobe for night flying. Its not like college catalog rights, FAA FARs don't grant historic rights. -Robert |
On 4 Jan 2006 09:39:41 -0800, "Robert M. Gary"
wrote: In this case the type certificate doesn't make a difference. The FAA current FARs seem to require a strobe for night flying. Its not like college catalog rights, FAA FARs don't grant historic rights. Welll... Kinda. I have wing tip position lights, but no rotating beacon. Just top and bottom strobes which are legal in that old airplane. Never plan on a single landing light working. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com -Robert |
I read it as you must have the anticollision light. We had to install
it on the Cessna 140 for this reason too. I think the only difference is that you have more choice in color because of your age. I don't see anything here that counters the statement "An approved aviation red or aviation white anticollision light system". 91.205.(c) (3) An approved aviation red or aviation white anticollision light system^M on all U.S.-registered civil aircraft. Anticollision light systems initially^M installed after August 11, 1971, on aircraft for which a type certificate^M was^M issued or applied for before August 11, 1971, must at least meet the^M anticollision light standards of part 23, 25, 27, or 29 of this chapter, as^M applicable, that were in effect on August 10, 1971, except that the color^M may^M be either aviation red or aviation white. In the event of failure of any^M light of the anticollision light system, operations with the aircraft may be^M continued to a stop where repairs or replacement can be made.^M |
"Robert M. Gary" wrote:
I read it as you must have the anticollision light. That's how I read it too. |
I am very interested in the response to this question as well.
My clipper came with a full electrical system, nav lights and a panel light, but no anti-collision. The rules for anti-collision coverage don't go back as old as my plane, yet I do not see any "grandfather" clause in the FARs. I know there are rules that are not articulated in the FARs sometimes (like shoulder harness rules). Does anyone here know the whole story? Mike "bstanton" null.com wrote in message ... I have a 1941 Chief with lights on it. There's one light on each wingtip and one on the top of the fin. There's no anticollision light/strobe or landing light. There are wires from the 3 position lights to the cockpit, where they end. The engine has no alternator or generator and never has had one. There's no battery, battery compartment, starter or electrical system. I do have a portable sealed lead acid battery that I charge between flights to power a radio and intercom. There's nothing in the paperwork about "day VFR only" and there's no AFM or even any POH. I've looked at 91.209 and 91.205 (c). I've got position lights, I won't be operating for hire, so I suppose a landing light is not legally required. I suppose a larger battery would be an adequate source of electrical energy for short flights. Can I fly at night if I install an anticollision light? Anyone want to comment on what I need to legally fly at night for short local flights? Does anyone think the disconnected lights have made the aircraft legally unairworthy for the last 65 years? Does anyone know how these were originally powered (Dry cells?) Thanks for any information. |
See an aircraft mechanic who will ...
install a legal anti-collision light (LED strobe uses the least power) fabricate a proper battery box for a battery, perhaps install a voltmeter, fabricate an electrical bus, circuit breaker and switch, perhaps an external power connection for charging, do the weight and balance and update the paperwork and aircraft logs. The airplane may have had an external wind-driven generator originally, you could restore that with a modern alternator at the cost of a 1 or 2 mph. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "bstanton" null.com wrote in message ... |I have a 1941 Chief with lights on it. There's one light on | each wingtip and one on the top of the fin. There's no | anticollision light/strobe or landing light. There are | wires from the 3 position lights to the cockpit, where they | end. The engine has no alternator or generator and never | has had one. There's no battery, battery compartment, | starter or electrical system. I do have a portable sealed | lead acid battery that I charge between flights to power a | radio and intercom. | | There's nothing in the paperwork about "day VFR only" and | there's no AFM or even any POH. | | I've looked at 91.209 and 91.205 (c). I've got position | lights, I won't be operating for hire, so I suppose a | landing light is not legally required. I suppose a larger | battery would be an adequate source of electrical energy for | short flights. Can I fly at night if I install an | anticollision light? Anyone want to comment on what I need | to legally fly at night for short local flights? Does | anyone think the disconnected lights have made the aircraft | legally unairworthy for the last 65 years? Does anyone know | how these were originally powered (Dry cells?) | | Thanks for any information. |
Is there room in a Chief to put an alternator? When I had my Chief we
thought about this for a minute and decided it was way too much work. I did look at a Champ that had the wind generator thing but it seemed that it put out very limited power. When you only have a few hundred pounds of useful load adding a battery can seem overwhelming. -Robert |
I'd call the local FSDO.
Similar Threads | ||||
FAA PPL night flight requirement - does it have to be DUAL? | Peter Clark | Piloting | 21 | January 6th 05 12:38 AM |
Night solo XC? | G. Burkhart | Piloting | 51 | October 14th 04 03:11 PM |
Night of the bombers - the most daring special mission of Finnishbombers in WW2 | Jukka O. Kauppinen | Military Aviation | 4 | March 22nd 04 11:19 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
