Add-on have to take the Knowledge test?
Old July 9th 20, 09:10 PM posted to rec.aviation.soaring
jp
Default Add-on have to take the Knowledge test?
As I interpret 14 CFR 61.63 (Additional aircraft ratings ...), particularly this part, an applicant for a category add-on rating:
(4) Need not take an additional knowledge test, provided the applicant holds an airplane, rotorcraft, powered-lift, weight-shift-control aircraft, powered parachute, or airship rating at that pilot certificate level.
it appears that a category add-on applicant is required to take the Knowledge Test if the applicant does not already have one of the specified certificates AT THE DESIRED CERTIFICATE LEVEL. Sorry about the caps.
If this interpretation is correct, if an applicant for a commercial add-on category rating has only a private pilot certificate the applicant is required to take the commercial Knowledge Test appropriate to the rating desired.
Is this interpretation correct?
Old July 9th 20, 09:50 PM posted to rec.aviation.soaring
Correct. A private pilot in airplanes adding a glider rating at private level does not need to take the glider written. A private pilot in airplanes adding a glider rating at commercial level does need to take the commercial glider written.
Old July 10th 20, 01:49 AM posted to rec.aviation.soaring
Correct (based on old regs).....a private power is some time (not enough usually), a signoff, check ride for private glider.....same for commercial.......basically, you have a level in power, just some time, signoff, check ride to add in the glider....no written,,,,,
Old July 10th 20, 06:22 AM posted to rec.aviation.soaring
SoaringXCellence
Also, If you don't have a private glider or a commercial, in any category, (as it appears from the question) you need a private glider before applying for a commercial glider.
Mike B. (former DPE)
Passed CFI Knowledge Test Kobra Instrument Flight Rules 14 August 19th 08 02:17 AM
Passed CFI Knowledge Test Kobra Piloting 10 August 6th 08 01:37 AM
FAA Knowledge test Dave Piloting 15 October 31st 03 06:32 PM
FAA Knowledge Test Results Richard Moore Instrument Flight Rules 4 October 12th 03 07:10 AM
FAA Knowledge Test Results Richard Moore Simulators 3 October 12th 03 04:48 AM
