13.5 WGC Contest Day 8: US Pilots
Old July 11th 17, 01:46 PM posted to rec.aviation.soaring
Default 13.5 WGC Contest Day 8: US Pilots
297km racing task today for Tony and Francois: Follow along on the 2 tracking sites:
http://live.glidernet.org/#c=46.55575,20.85812&z=9&s=1 or
http://glidertracker.de/#tsk=http://.../243266/xcsoar
Old July 11th 17, 06:19 PM posted to rec.aviation.soaring
Mike C
Rough day.
Climb to 2K ft. glide to 600 () ft. repeat.
Fat Albert
Kudos to Tony Condon, OK the FES helped, but drifting back across the town of Bekes below 500' in a bubble which gradually improved to a couple of knots and took him to 2,500ft took some chutzpah
Must be there or thereabouts for a day win
Old July 11th 17, 08:43 PM posted to rec.aviation.soaring
Tony[_5_]
Thanks Fat Albert, not sure what FES had to do with it. The terrain here in Hungary is much like my home of Kansas. Half of the fields are wheat, the harvest is in progress, and there are a million places to land. There also are a lot of Sunflowers here too. Just like home.
For the record, SeeYou says the bottom point of that climb was 780 ft. AGL.
It was quite the day, and that last climb was the ONLY climb that Francois and I did not share. We did a really nice job of staying together, which is not easy when you are going from one low save to another. I couldn't imagine a better teammate.
Old July 11th 17, 08:46 PM posted to rec.aviation.soaring
Tony[_5_]
Old July 11th 17, 09:59 PM posted to rec.aviation.soaring
Robin Clark
Way to go Tony! Congrats to you and Francois for great flying on a clearly difficult day. You climbed in an area that Sebastian used before the turn, but he didn't go back.
Old July 11th 17, 10:09 PM posted to rec.aviation.soaring
Duster[_2_]
No small bragging rights to beat the best in the world, if only even by a football field's length!
Old July 12th 17, 02:01 AM posted to rec.aviation.soaring
Fat Albert
Tony
I've flown in Hungary, do they still burn 2km square stubble fields by lighting all four sides at once with multiple vehicles towing burning rags? Often ducked clumps of burning straw when climbing in a field fire, Hungary is the only place I ever ducked a burning bale!
I've also flown an, admittedly non self launcher, FES sailplane.
My estimate of your above the ground height came from seeing altitude 250m or so on the tracker with the ground there about 100m ASL. Whatever, 500ft or 750ft, it was brave to drift off over what appeared to be an unlandable area at that height.
For me the decision would have been influenced by the FES, it's the only virtually instant start thermal-on-demand system out there, would you have made the same decision without the FES?
No criticism intended, that's the whole point of the FES to me, no compromise on soaring decisions, no abandoning of soaring because you've got an ion thermal [geddit :-)]
Uli didn't, he chose to land there pretty much.
Old July 12th 17, 06:36 AM posted to rec.aviation.soaring
Tony[_5_]
I've seen a few fires that I hypothesised were field fires but couldn't confirm.
For me, FES does not give me permission to fly over unlandable terrain. Yes it's quick and pretty reliable but I'm not betting my life on it and not risking the glider.
The thermal was at the edge of town, plenty of fields around. Uli was under me and ended up in a nice cut wheat field a few km outside if town so that is a good indication that we weren't soaring Iver unlandable stuff.
New Contest Pilots MNLou Soaring 5 July 22nd 14 10:20 PM
Question to Contest Pilots Scott Alexander[_2_] Soaring 3 June 15th 11 02:15 PM
Thanks to [US] Contest Pilots Chip Bearden Soaring 2 July 8th 08 05:41 PM
New products for US Contest Pilots from Random Logic... Marc Ramsey[_2_] Soaring 12 February 19th 08 09:59 PM
ALL USA CONTEST PILOTS [email protected] Soaring 6 January 11th 06 08:06 PM
