KLN90B GPS data cable
I need a Bendix King KLN90B GPS data loading cable.
Any suggestions as to where to look for one ? I'm in Athens Greece |
Put a PC DB-9 Connector in the aircraft and use a standard DB-9 Computer
Cable. Works Great! Michelle Kyprianos Biris wrote: I need a Bendix King KLN90B GPS data loading cable. Any suggestions as to where to look for one ? I'm in Athens Greece -- Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, Angel Flight Mid-Atlantic Volunteer Builder, Habitat for Humanity |
I have a KLN-89/B and made my own. It is a RS-232 cable with the funky
plug on one end that King has defined for the aircraft, and the normal computer connector on the other end. You can get the pin outs from the manual/. I was in Athens this past April and had a wonderful time. You folks pulled off a great Olympics. You should just keep them there. Ross Kyprianos Biris wrote: I need a Bendix King KLN90B GPS data loading cable. Any suggestions as to where to look for one ? I'm in Athens Greece |
Thank you Ross ;-)
"Ross Richardson" wrote in message ... I have a KLN-89/B and made my own. It is a RS-232 cable with the funky plug on one end that King has defined for the aircraft, and the normal computer connector on the other end. You can get the pin outs from the manual/. I was in Athens this past April and had a wonderful time. You folks pulled off a great Olympics. You should just keep them there. Ross Kyprianos Biris wrote: I need a Bendix King KLN90B GPS data loading cable. Any suggestions as to where to look for one ? I'm in Athens Greece |
"Kyprianos Biris" wrote in message ...
I need a Bendix King KLN90B GPS data loading cable. Any suggestions as to where to look for one ? I'm in Athens Greece I have a data loading cable for a KLN 89B that you could have. Will that work? Gerd |
Similar Threads | ||||
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | Home Built | 6 | October 15th 04 08:51 PM |
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | General Aviation | 0 | October 12th 04 05:11 PM |
Aviation Insurance History, data, records? | cloudclimbr | General Aviation | 0 | February 17th 04 03:36 AM |
rudder cable question | Bob Loer | Home Built | 7 | November 26th 03 08:34 AM |
Rudder cable - was The Little Wheel in Back | BD5ER | Home Built | 9 | September 11th 03 04:14 PM |
