Canard or Mooney
Old May 6th 08, 02:10 PM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
Gig 601Xl Builder
Default Canard or Mooney
Linton wrote:
Dave S explained on 5/4/2008 :
Linton Yarbrough wrote:
To make matters worser, I can't build one so I have to take someone
else's work. but the numbers of successful Cozys is a testament to
the design. plus, you get to install a rotary-Wankel; this is good?
The Cozy and the velocity were designed and intended to be used with a
"certified" horizontally opposed air cooled engine. Some enterprising
experimenters have used the rotary/wankel engine, with varying degrees
of success.
Dave
Dave I don't need varying degrees of success. I guess as the Capt said
if you want to tinker, maintain and build, then go EXP.
Maybe my next assessment is Mooney vs. ???
Cirrus, Cessna (Columbia), Piper, and of course, Beechcraft.
Old May 12th 08, 02:12 PM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
jsbougher
test, can't seem to post as get error from Google
On May 3, 9:35 am, Linton Yarbrough wrote:
I don't get the reason for the Cozy or the Velocity (which isn't selling
anyway) from the standpoint of speed, comfort, etc. The $$$ come out the
same for the most part and you don't have composite issues or trouble
getting things fixed. Pusher/tractor preferences aside, am I missing
something that would or does make one of the canards a better purchase?
Old May 12th 08, 02:16 PM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
jsbougher
The group you are posting to is a Usenet group. Messages posted to
this group will make your email address visible to anyone on the
Internet.
We were unable to post your message
If you believe this is an error, please contact Google Support.
Old May 12th 08, 02:18 PM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
jsbougher
Comments from a Velocity owner and aeronautical engineer who also
didn't have time to build, so bought instead. Additional comment is
that my Dad has a Mooney 201 that I've flown quite a bit so I think
I'm fairly well placed to at least comment on your question.
For me, there were a few big drivers for the Velocity.
1) Stall characteristics - I can pull the throttle, slow to stall
speed, roll into a 45 degree bank and pull the stick to my stomach and
nothing happens. I know this isn't an issue for "good" pilots, but
the records are littered with stall/spins. I'm human and make
mistakes. Whether rational or not, the stall/spin is one of my
biggest fears.
2) Maintenance / avionics - with a homebuilt, I can do everything
myself outside of the "annual". This has helped with the nuisance
issues, but I still use the local A&P for a lot of work.
Additionally, I have access to cutting edge development that is too
expensive or simply not available to certified aircraft. Example is
my Trutrak 2 axis autopilot / ADI. I absolutely love it and my Dad
can't put it in his Mooney without a LOT of effort if at all.
3) Factory support / aircraft complexity - factory support may not be
as good as Mooney, but in the experimental world the ability to get
factory check out and factory annual is a big deal. Also note that
the Velocity can perform extremely well as a VERY simple airplane. My
plane is fixed prop, fixed gear and keeps us with a 201. My plane is
more basic from a maintenance perspective than a Cessna 172 and was it
a simple transition from that plane.
4) Useful load - I can put myself, my wife, both kids, the dog and a
weekends worth of luggage into it and still easily cover 300-400
miles.
Jeff
Old May 12th 08, 02:20 PM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
jsbougher
Google sucks and won't let me post remainder of story. If you're
interested, let me know and I can e-mail.
Old May 12th 08, 03:25 PM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
Gig 601Xl Builder
It let you post 4 times in 10 minutes.
Old May 12th 08, 08:59 PM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
jsbougher
On May 12, 7:25 am, Gig 601Xl Builder
Yup, and not a single one is what I had in the message window.
Old May 12th 08, 09:15 PM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.owning
Gig 601Xl Builder
That's sort of spooky. You have a Google ghost.
Old May 21st 08, 09:54 PM posted to rec.aviation.student,rec.aviation.piloting,rec.aviation.homebuilt
Gezellig
I dunno. For an assortment of reasons, I have not been hanging around the
local airport for the past couple of years. But the one builder that I knew
who actually started flying a Wankel powered Cozy MkIV finally gave up and
switched to a Lycoming O-360. From what I have heard, he was unsuccessful at
cooling the Wankel; but the Lycoming is running without problems.
The only recommendations that I can make are to look/ask on
rec.aviation.homebuilt and also on the canard forum. (I have forgoten what
the canard forum is really called and/or where it is located, but someone on
R.A.H will be sure to know.)
Peter
Lint, my ex-brother-in-law has a Cozy IV and it is a super flight. He
bought his already built and has never had a problem except with the
front nose gear. The faster LD speeds! I think the Cozys are for those
who want to build, the Mooneys for those who don't care to.
Gazelle, this may be the answer. Even with a Lycoming, I see Jeff's
point about the annual; I am left confused in this, can I expect to get
an annual on a Cozy/Velocity type canard without having to do anything
myself?
Find another Cozy/Velocity owner and pay them?
canard flying boat Darrel Toepfer Home Built 14 October 19th 15 07:37 AM
My first four flights on an RJ.03 IBIS canard Hans Home Built 3 August 25th 07 06:43 PM
Aircraft ID? canard biz plane Ron Hardin General Aviation 5 October 1st 06 09:55 PM
Canard nose pading Paul Lee Home Built 6 January 9th 04 07:36 AM
Dumb Canard Question. Russell Kent Home Built 39 October 19th 03 03:25 PM
