Equipment Installation
We have a Controlvision AnyWhereMap system in our Saratoga and are upgrading
it to include the WxWorks XM Weather (noncertified version). The PDA will be replaced, necessitating replacement of the cabling from the PDA holder to the cigar-lighter plug which also serves the GPS that is velcroed onto the glare shield. We will use the Bluetooth XM receiver mounted (maybe with velcro to be a "temporary" installation and not a modification of the airplane) inside an unused panel space or in the nose baggage compartment. There are a lot of openings for the Bluetooth signal to get through, so we are going to try that. We will reuse the existing GPS. I would like to connect up a gel lead-acid battery to provide backup power to the AnyWhereMap system for backup navigation. I would like to pick off ship's power from an existing unused 5A breaker, put a SPDT NORMAL/EMERGENCY switch on the now-blank panel over the unused ADF slot, and connect the battery to the other side of the switch. We will remove the backup battery for charging external to the airplane. I can put an inline fuse in the battery lead at the battery. Question: Does this kind of installation work require A&P or IA signoff? Does it require FSDO approval? Does W&B needed to be signed off? Stan |
Similar Threads | ||||
magneto installation help | Dick | Home Built | 5 | February 10th 05 03:02 PM |
Great deals on avionics installation kits and tools | Randy Cooper | Aviation Marketplace | 0 | January 14th 05 04:07 AM |
Must the PLANE be IFR-equipped to fly over17,500? | john smith | Home Built | 11 | August 27th 04 02:29 AM |
Equipment List Required Documentation | O. Sami Saydjari | Owning | 9 | April 21st 04 02:57 AM |
Equipment Lists | Charles Talleyrand | Military Aviation | 5 | September 12th 03 02:34 AM |
