O200 engine
Hello,
I search where is, in the engine, the PN 633309-8 (bearing needle). I don't found yet in the IPC... Where may I buy a full overhaul kit, this kit must be send overseas in Europe. Thanks -- Volem rien foutre al païs! Philippe Vessaire Ò¿Ó¬ |
O200 engine
On Thu, 16 Aug 2007 09:22:54 +0200, Philippe Vessaire
wrote: Hello, I search where is, in the engine, the PN 633309-8 (bearing needle). I don't found yet in the IPC... Where may I buy a full overhaul kit, this kit must be send overseas in Europe. Thanks have you munged that part number? 633609-8 is a 'bearing, needle' which the overhaul manual puts as item -21B on the drawing for that section. if you flip back a page to figure 3 you'll find it on the item that inserts on the lower left case half on the drawing. I've never pulled it apart so I'm not sure what it is. Stealth Pilot |
O200 engine
("Philippe Vessaire")
I'm stealing THIS! Ò¿Ó¬ Paul-Mont :-) |
O200 engine
Montblack wrote:
I'm stealing THIS! Ò¿Ó¬ you may, it's copyleft -- Volem rien foutre al païs! Philippe Vessaire Ò¿Ó¬ |
O200 engine
Stealth Pilot wrote:
I search where is, in the engine, the PN 633309-8 (bearing needle). I don't found yet in the IPC... have you munged that part number? 633609-8 is a 'bearing, needle' which the overhaul manual puts as item -21B on the drawing for that section. if you flip back a page to figure 3 you'll find it on the item that inserts on the lower left case half on the drawing. I've never pulled it apart so I'm not sure what it is. I think you are right.... but only an item number, no drawing.... It's why I don't see. thanks again. -- Volem rien foutre al païs! Philippe Vessaire Ò¿Ó¬ |
O200 engine
("Philippe Vessaire" wrote)
I'm stealing THIS! Ò¿Ó¬ you may, it's copyleft Well all right then. Paul-Mont Ò¿Ó¬ |
O200 engine
On Thu, 16 Aug 2007 17:32:41 +0200, Philippe Vessaire
wrote: Stealth Pilot wrote: I search where is, in the engine, the PN 633309-8 (bearing needle). I don't found yet in the IPC... have you munged that part number? 633609-8 is a 'bearing, needle' which the overhaul manual puts as item -21B on the drawing for that section. if you flip back a page to figure 3 you'll find it on the item that inserts on the lower left case half on the drawing. I've never pulled it apart so I'm not sure what it is. I think you are right.... but only an item number, no drawing.... It's why I don't see. thanks again. what you need is a copy of the Continental Aircraft Engines Series C-75,85,90 & O-200 Service Parts Catalogue this has exploded views of the group assemblies and a breakdown of the parts that go into each assembly. I just discovered that my read of the exploded view missed something. the needle bearing in question is part of the starter clutch assembly. if you cant find a copy I could scan it and sent a copy by email. it is 58 pages. Stealth Pilot |
O200 engine
what you need is a copy of the Continental Aircraft Engines Series C-75,85,90 & O-200 Service Parts Catalogue I own that, but the needles are not design and I did't found the the PN in the list. Thanks -- Volem rien foutre al païs! Philippe Vessaire Ò¿Ó¬ |
Similar Threads | ||||
Engine-out procedures and eccentric forces on engine pylons | Mxsmanic | Piloting | 18 | May 26th 07 01:03 AM |
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg | [email protected] | Aviation Photos | 1 | April 11th 07 04:48 PM |
F-1 Engine for the Saturn V S-IC (first) stage depicts the complexity of the engine 6413912.jpg | [email protected] | Aviation Photos | 0 | April 9th 07 01:38 PM |
O200 nose | Philippe | Home Built | 0 | July 22nd 05 08:09 PM |
1710 allison v-12 engine WWII p 38 engine | Holger Stephan | Home Built | 9 | August 21st 03 08:53 AM |
