L-Nav question for anyone still using one
Old May 4th 16, 07:49 PM posted to rec.aviation.soaring
akiley
Default L-Nav question for anyone still using one
I just started flying an ASW-19b at our club that has an L-Nav, GPS-NAV, Vario combo installed. When I turn the unit on, I get the barro page. I can set the altimeter here but the Go button does nothing. So I can't get to the main screen. Yesterday I gave up, left the L-Nav on. About 3 or 4 minutes later (on tow), the main screen came up on it's own.
Am I doing something wrong? I RTFM, but am guessing the Go button is flaky and maybe the barro page times out after a few minutes. Everything else works once I get to the main menu.
Old May 4th 16, 08:31 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Your first guess is correct. The "GO" button is flakey. I don't think there is a timeout for a screen change. Will fire one up tonight and let it sit to see for sure. Gary at Clearnav will tell you that the switches sometimes go bad. I have a few GPS Nav displays I am going to have to send back for bad switches. As I recall, about one hour bench time, and last time was, I think, $5 per switch. But, Gary at Clearnav can fix you right up!
Steve Leonard
Old May 4th 16, 08:57 PM posted to rec.aviation.soaring
akiley
Steve Leonard
Good deal! Thanks for that. ... Aaron
Old May 5th 16, 04:38 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
As a follow up, there is no auto time to transition to the main page. At least, it didn't happen in the 8 hours I had mine on for last night.
Steve
Old May 5th 16, 07:16 PM posted to rec.aviation.soaring
Had the GO button replaced last year by Gary at ClearNav. Had gotten increasingly less cooperative (the button, not Gary). Lasted 23 years, though. Still a fine instrument.
Chip Bearden
JB
IFR GPS question Robert M. Gary Piloting 14 October 10th 06 07:10 PM
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 01:11 AM
ME-262 A-1a/U4 question Prowlus Military Aviation 7 February 27th 04 06:20 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 01:26 AM
