#21
Pitch vs. trim in flight phases
Your description of yoke pressure is vastly different from that we who
fly ga aircraft experience, which explains why you do not understand ga trimming procedures. We feel the pressure on the yoke reducing as trim is corrected. You don't. We maintain the desired attitude (note - "attitude" ) with the yoke and trim away the pressure. You can't. This is basic piloting, the notion of trimming away yoke pressure happens in the first hour of flight training for a PP. .. Is there any question as to why your pronouncements regarding GA are viewed with suspicion? On May 16, 2:49 pm, Mxsmanic wrote: Robert M. Gary writes: I'm not sure how you can without a force feedback joy stick. You use the trim to remove pressure from the yoke. As I've explained, I can trim until I no longer need to hold the joystick away from the neutral position. The stick is spring-loaded, which provides a so-so simulation of control pressure. I've read that force-feedback sticks are so inaccurate that it's better to just have a stick with springs. |
Tina writes:
Your description of yoke pressure is vastly different from that we who fly ga aircraft experience, which explains why you do not understand ga trimming procedures. It is not "vastly different," merely different. Don't overestimate the importance of minor differences. If such differences were that important, then pilots would have to start learning from scratch again every time they moved from one aircraft to another. We feel the pressure on the yoke reducing as trim is corrected. You don't. Yes, I do. The closer I am to correct trim, the less I have to move the joystick from its neutral position, and the less spring pressure there is on my hand. When the aircraft stays put without me touching the stick at all, it is trimmed correctly. Is there any question as to why your pronouncements regarding GA are viewed with suspicion? How often do you fly with MSFS, and what configuration do you use? |
Ken S. Tucker wrote:
Quick question, (it's been awhile since I've piloted) is the trim (Cessna 152) in the center, right of the pilot, and has zero mark to be set null in pre-flight? Correct. (Well it has a "takeoff position" which is more or less center.) In the '74 PA-28R I rent it's between the seats and harder to see, and takeoff position is about "a quarter-inch back" on the slot since there's no visible mark. I don't like the trim-wheel there. The first time I flew in the right seat and reached for the trim handle I cracked my knuckle against the door. -c |
#24
On May 17, 7:05*am, Mxsmanic wrote:
Tina writes: Your description of yoke pressure is vastly different from that we who fly ga aircraft experience, which explains why you do not understand ga trimming procedures. It is not "vastly different," merely different. *Don't overestimate the importance of minor differences. *If such differences were that important, then pilots would have to start learning from scratch again every time they moved from one aircraft to another. We feel the pressure on the yoke reducing as trim is corrected. You don't. Yes, I do. *The closer I am to correct trim, the less I have to move the joystick from its neutral position, and the less spring pressure there is on my hand. *When the aircraft stays put without me touching the stick at all, it is trimmed correctly. Is there any question as to why your pronouncements regarding GA are viewed with suspicion? How often do you fly with MSFS They have an airline? Cheers |
#25
Mxsmanic wrote:
Yes, I do. The closer I am to correct trim, the less I have to move the joystick from its neutral position, and the less spring pressure there is on my hand. When the aircraft stays put without me touching the stick at all, it is trimmed correctly. That the general idea, but in an airplane the stick isn't generally -moved- (except at very slow speeds); rather, pressure is exerted on it by the pilot to counter the forces exerted by the airflow over the control surfaces. I recommended to somebody else that they call around the local flight schools and see if they can find a Frasca-type simulator like this one http://www.frasca.com/body/TruVision170.Lo.jpg and spend a half-hour or so in it. The pressure feedback is strikingly similar to that of a small airplane, and you'll get a good sense of the correct feel as well as the correct use of trim to alleviate control pressure. "During flight, it is the rudder -pressure- the pilot exerts on the control yoke and rudder pedals that causes the airplane to move about the axes. When a control surface is moved out of its streamlined position (even slightly), the air flowing past it will exert a force against it and will try to return it to its streamlined position. It is this force that the pilot feels as pressure on the control yoke and the rudder pedals." Airplane Flying Handbook I imagine it would be pretty expensive, but I'd really like to see a motorized flight sim yoke that accurately represents control surface pressures. I have all the hardware (spare Battlebot parts) to make a dual-axis prototype, but not enough knowledge of the software interface or specific pressure values. -c |
#26
Mxsmanic wrote:
Tina writes: Perhaps the difference between the MSFS and reality is the notion of adjusting trim to take pressure off the yoke is one of those 'it doesn't matter in simulated flight' issues. Some controls for use with the sim, including the Saitek X52 joystick that I have, are spring loaded, and MSFS behaves in such a way that you must maintain pressure against the springs if the aircraft isn't properly trimmed. I don't know how that compares to the Saitek Aviator which is what I use, but I'm thinking of removing the springs and replacing them with stiffer ones to make it a bit more realistic. -c |
#27
On May 16, 12:19 pm, gatt wrote:
Ken S. Tucker wrote: Quick question, (it's been awhile since I've piloted) is the trim (Cessna 152) in the center, right of the pilot, and has zero mark to be set null in pre-flight? Correct. (Well it has a "takeoff position" which is more or less center.) In the '74 PA-28R I rent it's between the seats and harder to see, and takeoff position is about "a quarter-inch back" on the slot since there's no visible mark. I don't like the trim-wheel there. The first time I flew in the right seat and reached for the trim handle I cracked my knuckle against the door. Ok thanks. I was ok with the location of the trim wheel, but the adjustment was too coarse for me, but I could be a bitchy sissy. My wheel was graduated, with a zero mark and did not quite give the fine adjustment I wanted. That could be cables out to the tail, I should have learned the mechanism! Regards Ken |
#28
gatt wrote:
Mxsmanic wrote: Tina writes: Perhaps the difference between the MSFS and reality is the notion of adjusting trim to take pressure off the yoke is one of those 'it doesn't matter in simulated flight' issues. Some controls for use with the sim, including the Saitek X52 joystick that I have, are spring loaded, and MSFS behaves in such a way that you must maintain pressure against the springs if the aircraft isn't properly trimmed. I don't know how that compares to the Saitek Aviator which is what I use, but I'm thinking of removing the springs and replacing them with stiffer ones to make it a bit more realistic. -c Ah yes......but at what airspeed? (slugs dynamic pressure vs unboosted control surfaces :-)) -- Dudley Henriques |
#29
"Mxsmanic" wrote in message
... Tina writes: Your description of yoke pressure is vastly different from that we who fly ga aircraft experience, which explains why you do not understand ga trimming procedures. It is not "vastly different," merely different. Don't overestimate the importance of minor differences. If such differences were that important, then pilots would have to start learning from scratch again every time they moved from one aircraft to another. It is, in fact, vastly different. I have flown many different aircraft, and have never had to ask someone how to trim the plane. I recently purchased FS2004, and if you care to check google groups, you'll see I did need to ask how to trim. |
#30
"Mxsmanic" wrote Yes, I do. The closer I am to correct trim, the less I have to move the joystick from its neutral position, and the less spring pressure there is on my hand. When the aircraft stays put without me touching the stick at all, it is trimmed correctly. That's the difference, and it is a big difference. In an airplane you might be holding forward pressure on the yoke at say 2 lbs to hold a particular attitude. As you start rolling in forward trim the force required to hold the yoke in the position it is currently being held diminishes until it is gone altogether. The yoke never moves but the force required to hold it where it is diminishes to zero. In your sim what happens is that as you roll in forward trim you have to move the yoke back to compensate which results in less spring pressure based on the new position of the yoke - the previously held desired attitude now occurs with the yoke in a different position. This is not at all how it works in an airplane, and not at all how it feels to the pilot. In addition, in my experience the springs in these toy yokes and joysticks do not feel at all like normal control pressures in an airplane - the "feel" is all wrong and the force curves are not the same. BDS |
Similar Threads | ||||
Typical power settings during cruise and other phases of flight | Mxsmanic | Piloting | 99 | October 2nd 06 10:12 AM |
Making a pitch trim indicator for a Glasair | [email protected] | Home Built | 5 | September 13th 06 02:30 AM |
$30,000 pitch links | Stuart Fields | Home Built | 3 | January 16th 06 02:13 AM |
Cherokee Electric Pitch Trim | Jonathan Goodish | Owning | 4 | November 18th 04 02:43 AM |
ALTRAK pitch system flight report | optics student | Home Built | 2 | September 21st 03 11:49 PM |
