Ventus TN 349-42
Old December 4th 20, 03:42 PM posted to rec.aviation.soaring
Stuart Venters
Default Ventus TN 349-42
As part of annual, I just found this newish TN regarding corrosion in
the flaperon inside the wing linkage. (No corresponding AD.)
I looked inside with a USB camera and saw some minor stuff. Definitely
will re-lube.
I'm curious what folks are seeing with this and if they are adding
access ports?
Old December 5th 20, 12:47 PM posted to rec.aviation.soaring
jld
Here is the AD:
https://ad.easa.europa.eu/ad/2020-0063
The info is available on SChempp Hirth website, details are in 825-57 Rev.4
This is a recurring AD which needs to be cw at every annual inspection.
access ports?
Old December 5th 20, 02:29 PM posted to rec.aviation.soaring
Jim N
I purchased a Wi-Fi endoscope to check things out and found no corrosion.
Ventus C, 15m vs 17.6m Mike N. Soaring 22 August 4th 19 05:22 PM
Ventus bT BillT Soaring 2 March 19th 11 09:38 AM
FS: Ventus C KO Soaring 2 January 7th 06 05:14 PM
FS: Ventus C KO Soaring 1 January 5th 06 11:28 PM
FS: Ventus C KO Soaring 9 November 5th 05 12:58 AM
