#11
In article . net,
"Mike Rapoport" wrote: "Paul Tomblin" wrote in message ... In a previous article, "Mike Rapoport" said: I was given a bottle of this stuff at NBAA and today I tried it out for the Wasn't there a problem with the original Simple Green that it could attack aluminium or something? How did they fix that with the Aviation Cleaner? Yes there is a corrosion issue with regular Simple Green. The new Extreme Simple Green is different, it isn't even green. Mike Not a chemist I have been using Carbon X, which is Ph neutral -- the problem with regular Simple Green is that it is acidic and will attack aluminum and magnesium. I would presume that the new Extreme Simple Green is a similar product to Carbon X -- the prices appear to be about the same. I have been using a 10% - 30% mixture of Carbon X in a spray bottle to remove bugs -- I let it soak a couple of minutes and then wipe the bugs off with a wet sponge. It does not attack dope or paint -- something which 409 will do. I assume that Extreme Simple Green would normally be applied in diluted form, too. |
"Orval Fairbairn" wrote in message news I have been using a 10% - 30% mixture of Carbon X in a spray bottle to remove bugs -- I let it soak a couple of minutes and then wipe the bugs off with a wet sponge. It does not attack dope or paint -- something which 409 will do. I assume that Extreme Simple Green would normally be applied in diluted form, too. Well, that answers my question (from another post)!! Thanks, that'll solve a BIG problem for me (okay ,a bug sized problem). Matt -- "A mind, like a home, is furnished by its owner, so if one's life is cold and bare he can blame none but himself." -- Louis L'Amour |
Not long ago, I posted the real secret to leading edge bug cleaning ---
soak time. No matter what you use, and surely some formulations are better than others, letting them soak (i.e. remain wet) for an hour or even hours will make removal a breeze. Worried about paint? Use plain water. Keeping a LE wet may require a hangar, cool day, rags or whatever but soak time really saves the elbow grease. Now if I can just get the turbine exhaust stains off my Maule.... Matt Barrow wrote: It doesn't damage the paint? In the late srping around here we get moths out the wazoo and I'l like to just spray the leading edges down to get the crap off but I woory about the paint (as others have aluded to). I have a really good paint job and don't want to ruin it. |
"Maule Driver" wrote in message .. . Not long ago, I posted the real secret to leading edge bug cleaning --- soak time. No matter what you use, and surely some formulations are better than others, letting them soak (i.e. remain wet) for an hour or even hours will make removal a breeze. Worried about paint? Use plain water. Keeping a LE wet may require a hangar, cool day, rags or whatever but soak time really saves the elbow grease. Now if I can just get the turbine exhaust stains off my Maule.... I have the hanger, but your idea of rags (in my case we have a bunch of old towels) we can soak and hang over the LE sounds great. My heavy flying starts about this time of year and the bug (moths) season starts about the end of April. Being it can be pretty dry (compared to back East) the bug removal process can be much more difficult if they aren't soaked right away. Matt Barrow wrote: Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
Similar Threads | ||||
new cleaning product: Simple Green for aircraft | [email protected] | Owning | 19 | February 17th 05 06:15 AM |
Belly Cleaning...? | zatatime | Owning | 48 | July 6th 04 04:33 AM |
