Moving Gliders
Best practices for moving gliders around?
Stacking the hangar... Staging... Clearing the runway... I've recently been told that the Europeans never move a glider by the wingtips, but it's almost a necessity when stacking our hangar. (Gliders are on wheel sleds, so the load is not high.) Things can be tight and we often need someone on each wing to prevent hangar rash, but don't have someone as a wingroot pusher. There are some significant some differences of opinions due to various culture and practices differences from previous clubs. So, what does your club do? Paul A. |
Moving Gliders
Moving Gliders
I've seen that before and it doesn't answer the questions.
PA |
Moving Gliders
Moving Gliders
keskiviikko 9. toukokuuta 2018 4.49.57 UTC+3 Paul Agnew kirjoitti:
Best practices for moving gliders around? Stacking the hangar... Staging... Clearing the runway... I've recently been told that the Europeans never move a glider by the wingtips, but it's almost a necessity when stacking our hangar. (Gliders are on wheel sleds, so the load is not high.) Things can be tight and we often need someone on each wing to prevent hangar rash, but don't have someone as a wingroot pusher. There are some significant some differences of opinions due to various culture and practices differences from previous clubs. So, what does your club do? Paul A. If the hangar floor is flat concrete (as it always is), we sometimes push from the wingtips as the force is very low. On soft ground we try to prevent unnecessary wear on the fittings by pushing from wing root or mid-wing location. Always hilarious to read "Europeans do" something |
Moving Gliders
Move the wingtip forwards and backwards - if there is play between the wing and the fuselage then the glider has been pulled around by the tips. Longer wings more likely to develop play due to this. Well that is what was told to me by my instructor when I was a student - so just never pulled a glider forwards and backwards by the tips. A glider on a dolly that you pushing/pulling sideways by the tips would experience different forces and the wear is not likely be as pronounced.
Moving Gliders
If we wait long enough, somebody of dubious credential will come along and say that pushing on the wingtips is just fine. Have at it.
Moving Gliders
On Wednesday, May 9, 2018 at 11:38:35 PM UTC+12, son_of_flubber wrote:
If we wait long enough, somebody of dubious credential will come along and say that pushing on the wingtips is just fine. Have at it. No credentials, but a couple of questions: 1) what is the function of "drag pins" 2) how much load is put on things by pushing a glider around by the wing tips compared to opening the brakes at high speed, or by a Vne dive with brakes open? (and is either "necessary"?) |
Moving Gliders
"Drag pins" - clothed as the opposite gender?
On 5/9/2018 6:07 AM, Bruce Hoult wrote: On Wednesday, May 9, 2018 at 11:38:35 PM UTC+12, son_of_flubber wrote: If we wait long enough, somebody of dubious credential will come along and say that pushing on the wingtips is just fine. Have at it. No credentials, but a couple of questions: 1) what is the function of "drag pins" 2) how much load is put on things by pushing a glider around by the wing tips compared to opening the brakes at high speed, or by a Vne dive with brakes open? (and is either "necessary"?) -- Dan, 5J |
Moving Gliders
On Wednesday, May 9, 2018 at 5:07:21 AM UTC-7, Bruce Hoult wrote:
1) what is the function of "drag pins" In typical sailplane practice, there are no "drag pins" per se; drag and thrust loads are accommodated by a torque couple comprised of spanwise tension outboard on the wing main spar and spanwise compression inboard applied between the flat faces at the root of the lift pin and at the end of the pin socket it fits into. The loads reacted in this manner are primarily forward thrust loads, which in the normal flight envelope are much greater than the drag loads. Of course, abnormal overloads are most often drag loads applied when the wingtip encounters an obstacle on takeoff or landing. 2) how much load is put on things by pushing a glider around by the wing tips compared to opening the brakes at high speed, or by a Vne dive with brakes open? (and is either "necessary"?) Just for arguement, let's consider a 15m glider with VNE-limiting airbrakes going straight down. Our hypothetical glider has a non-lifting mass of 500 lbs, so we know that the the brake on each wing is delivering 250 lbs of drag into the fuselage. Each airbrake is located 100" outboard of the root. The distance between the wing main spar and the aft lift pin is 12". Simple statics suggests that the compression force applied at each aft lift pin is on the order of 250lbf*100"/12" = ~2080 lbf. For comparison, this compression force would be developed by an aft pull on the wingtip of 2080lbf*12"/300" = ~83 lbf. As I recall, US FAR Part 23 and the very similar JAR/CS 22 specify that a normal category glider be able to accommodate a 100 lbf chordwise force at the wingtip unless lower can be rationally justified. My impression is that most gliders are certificated to lower tip forces, the rational justification being "we handle them with care." As I understand the issue at the root of this discussion, the problem is not so much overloads, but rather wear between the lift pins and sockets. Gliders being moderately limber, when you apply a chordwise force at the tip it separates the pin and socket from full engagement by some small but non-trivial amount; let's guess around 0.020" (0.5mm). And when the force is removed or reversed, the pin and socket go back together. Repeated cycles of this half-mm movement can, over time, result in wear and looseness. Remember that the wings typically weigh between 120 and 180 lbs each, so that's a vertical force of 60 to 90 lbs at each pin and socket connection while they're being worked in and out. For the gliders I've designed, my advice is that an occasional chordwise force at the tip of up to 50 lbf while parking or moving the glider is not an issue. However, repeated cycles, for example when moving the glider from one end of the runway to the other, should be avoided when practical. --Bob K. |
Similar Threads | ||||
Moving Pictures 7/16/15 | Byker | Aviation Photos | 0 | July 16th 15 09:07 PM |
Moving Pictures 7/16/15 | Byker | Aviation Photos | 0 | July 16th 15 09:06 PM |
PDA for Moving Map | brian whatcott | Soaring | 18 | December 20th 09 01:52 AM |
Moving to CA | Ishrat Zahid | Piloting | 30 | May 20th 04 10:59 PM |
