Battery safety (againish)
Old March 16th 19, 04:05 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Battery safety (againish)
Was wondering if others had read and were doing this:
https://www.dg-flugzeugbau.de/wp-con...2019-103-e.pdf
The ASG-29E has a gas tank directly above two batteries used to power flight instruments.
Old March 16th 19, 05:04 PM posted to rec.aviation.soaring
kinsell
Interesting that they say to add epoxy to the casing. Putting a fuse at
one of the battery terminals would be a more conventional way of
handling it, and would allow for easier battery replacement.
Old March 16th 19, 07:10 PM posted to rec.aviation.soaring
Andrzej Kobus
You are missing the point. The fuse will not protect against internal short.
Old March 16th 19, 11:35 PM posted to rec.aviation.soaring
kinsell
No, not missing the point. The way I read it, they're talking about an
battery holder added around the battery. You wouldn't normally call
internal wiring "battery cables". Maybe something got lost in translation.
If anybody is using a battery so poorly constructed that it shorts out
internally and catches fire, that battery should be discarded immediately.
Old March 17th 19, 12:34 AM posted to rec.aviation.soaring
Andrzej Kobus
They are not adding a housing they are internally fixing it with PU resin because they had internal short circuit.
Old March 17th 19, 12:47 AM posted to rec.aviation.soaring
Dan Marotta
Some, maybe all LiFePO4 batteries are made up of individual cells wired
together in series to make up the full voltage.Â* If that setup is simply
stuffed into a plastic case and not secured, things can rattle around,
possibly allowing uninsulated interconnecting wires to short together.Â*
I might try stuffing foam into the battery case rather than filling it
with resin.Â* A fuse on the output cable should be considered mandatory.
Dan, 5J
Old March 17th 19, 02:23 AM posted to rec.aviation.soaring
Jonathan St. Cloud
The way I read it is a small hole is drilled in the case and resin injected...?
Old March 17th 19, 03:31 AM posted to rec.aviation.soaring
Many of us are flying with multi-cell LiFePO4 batteries that have internal wiring and are not filled with resin. Is that a problem? Or is the location of the batteries in this specific glider such that the resin is advisable? A battery fire anywhere in a glider (even without a fuel tank) is catastrophic. OTOH I havn't heard of any fires with this type of battery. It's the lithium-polymer battery pack (also much larger, with many more cells) in the FES systems that has had fires.
Old March 17th 19, 04:46 AM posted to rec.aviation.soaring
kinsell
Well, the service bulletin talks about an LFP that burned. There was a
fire in an EB-28 in Finland last year with a 10 A-H LFP. Here's a video
of an LFP burning:
https://www.pilotsofamerica.com/comm...-fires.102016/
There have been claims that LFP's don't burn, but that's simply not true.
Old March 17th 19, 08:09 AM posted to rec.aviation.soaring
bumper[_4_]
Probably not if a self launch is electric or has a Wankel engine that isn't doing its best to rattle your teeth fillings loose. With an engine that could pass for a paint mixer, the resin may keep things from rattling enough to chafe and perhaps short the battery internals.
PDA Battery [email protected] Soaring 4 December 28th 13 10:02 AM
USA / The Soaring Safety Foundation (SSF) Safety Seminars 2008 [email protected] Soaring 0 November 8th 07 11:15 PM
Find a Safety Pilot in your area with Safety Pilot Club Safety Pilot Club Instrument Flight Rules 0 December 29th 06 03:51 AM
The Soaring Safety Foundation (SSF) Safety Seminars Hit The Road in the USA [email protected] Soaring 0 September 11th 06 03:48 AM
