#21
Fiber optic guide for nav lights
Morgans wrote:
"Ernest Christley" wrote The easiest way is to just use the bits you already have in your toolbox and modify your technique to suit the material. I disagree. The right way to drill _any_ material, is to us the correct bit for the job. You wouldn't use a concrete bit for drilling steel. You wouldn't use a wood bit for drilling concrete. You don't know me very well, do you? 8*) Probably wouldn't use the concrete bit on steel. The tip is brittle. If the concrete isn't to thick, though, the wood bit will work in a pinch (as long as it's a cheap bit. Someone will catch hell if they use my GOOD wood bits on concrete.) What you are proposing does work, most of the time. It is _not_ the correct way, though, no matter what you say. What I'm proposing has worked every time I have ever tried it, and as long as I end up with an appropriately sized hole...which is the desired outcome...how can it be incorrect? Just because they make a specialize bit for each and every material on the market doesn't mean I have to buy and track one of each (the buying sucks, the keeping track so that it is around when you need it...oh, that's the pits). -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
"Ernest Christley" wrote Just because they make a specialize bit for each and every material on the market doesn't mean I have to buy I modify my own bits. and track one of each (the buying sucks, the keeping track so that it is around when you need it...oh, that's the pits). The finding it when you need it? Yep, that is my problem. I don't worry about it. I can modify a new one in less than a minute, so I just make another, usually. I'm glad your method works for you, but I'm gun-shy. I've broken parts, and had them break later due to what I think was heat stress from the drilling. Different strokes for different folks. You say tomato, I say tomatoe. ;-) -- Jim in NC |
Similar Threads | ||||
Panel Lights - Need Help | Barnyard BOb - | Home Built | 2 | May 29th 04 07:51 PM |
Anti collision light mod for Piper Arrow 1968 model? | Frode Berg | Owning | 4 | May 20th 04 05:16 AM |
Building chasing airport lights -- Attn: Jim Weir? | Jay Honeck | Owning | 79 | February 29th 04 02:10 PM |
