Batteries (again) - 2 Main Batts plus Tail Fin Batt wiring/switching
Old November 19th 07, 10:20 AM posted to rec.aviation.soaring
Neil Allison
Default Batteries (again) - 2 Main Batts plus Tail Fin Batt wiring/switching
Hi,
Time to dust off a perennial topic
I looked through the archives and read Darryl Ramm's battery
presentation. Not an exhaustive search but I didn't find an answer to
my question.
At present we have two (fused) 12V 7Ah "main batteries" connected to
the Master switch via an SPDT "changeover" switch. We are adding a
smaller capacity tail fin battery as a "reserve".
Without using diode switching and keeping it as simple as possible for
multiple club pilots, I can see 3 possibilities that I've illustrated
he
http://www.avon-tech-solutions.co.nz...derBattery.pdf
- select 1 of the three batteries using two SPDT "changeover" switches
in "series"
- separately isolate the tail battery in parallel to the currently
selected master
- separately isolate the tail battery in parallel to the master switch
Each has its advantages and disadvantages. No doubt there are more
possibilities. I expect to add the recommended Volkslogger "hold up"
circuit separately (or power the logger and possibly a PDA from a
dedicated battery, much like the self contained battery/logger systems
previously discussed here on r.a.s.).
What wiring / switching schemes are you using for this 3 battery
arrangement?
Thanks for your suggestions.
Neil
Old November 19th 07, 01:29 PM posted to rec.aviation.soaring
HL Falbaum
Schleicher uses a rotary switch
Batt 1, Batt 2, Batt 3, Off.
If you can get one of these, it reduces to one switch.
Hartley Falbaum
"Neil Allison" wrote in message
Hi,
my question.
he
in "series"
selected master
arrangement?
Neil
Old November 20th 07, 01:26 AM posted to rec.aviation.soaring
Martin Gregorie[_1_]
I just checked the Maplins online catalog (Maplins is the UK equivalent
of Radio Shack) for their standard range of panel mount rotary switches.
These are 1,2,3 and 4 pole types (12,6,4 and 3 positions). They have a
movable stop so you can blank off unwanted positions. Something like
these is available pretty much anywhere.
They are rated at up to 5 amps, so should be OK in a glider panel.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Switching Batteries Advice? ContestID67 Soaring 17 January 12th 06 01:02 AM
Pneumatic switching? bumper Soaring 5 March 15th 05 02:58 AM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 01:34 PM
Switching instructors? Dave Jacobowitz Piloting 13 November 5th 04 09:32 PM
Switching to ground.... David Rind Piloting 85 April 16th 04 06:53 PM
