New Trig TT22 Transponder
Old January 14th 10, 06:59 PM posted to rec.aviation.soaring
Paul Remde
Default New Trig TT22 Transponder
Hi,
Trig has announced the new TT22 transponder. It is identical to the TT21,
except that it is a Class 1 transponder with 250W output. That means it is
certified for use up to 35,000 feet.
Details: http://www.cumulus-soaring.com/trig.htm
The TT21 has been extremely popular.
I imagine that most glider pilots will use the TT21 because it uses less
power. It is rated for use up to 15,000 feet, but works up to 35,000 feet.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old January 14th 10, 07:27 PM posted to rec.aviation.soaring
John Smith
Just to clarify what this means: If you happen to fly in a region where
a transponder is mandatory, then class 1 is required above 15'000 feet.
TRIG TT21NOW IN STOCK Tim Mara[_2_] Soaring 5 September 29th 09 10:29 PM
TRIG TT21 Transponders Tim Mara[_2_] Soaring 12 September 26th 09 02:01 AM
Trig TT21 Transponder receives FAA TSO approval Paul Remde Soaring 12 September 19th 09 02:47 PM
Trig TT21 in Experimental Aircraft Paul Remde Soaring 5 July 5th 09 03:15 AM
Trig TT21 Transponder Thoughts? jcarlyle Soaring 16 June 23rd 09 04:38 PM
