Pawnee auxiliary oil cooler STC -- need info.
Old June 24th 19, 03:40 AM posted to rec.aviation.soaring
RV 6 Driver
Default Pawnee auxiliary oil cooler STC -- need info.
I am working on a Pawnee (PA25-235) that has an old STC (SA300SO) installed on it allowing for a 2nd oil cooler. The STC was added in 1965. The owner of the STC was Memphis Aero Corp and is apparently out of business. I am needing the installation instructions for this. Does anyone within the sound of my voice happen to have it? If so, will you allow me to see copies of it? Thanks in advance.
Old June 24th 19, 01:11 PM posted to rec.aviation.soaring
Bob Youngblood
I will look and see if I can find my info on that STC. My Pawnee has that STC and the unit is installed. The best source of information would be from a guy at Aerial Banners in Ft. Lauderdale. Dan Manera, is the best source of information on the Pawnee in the country. He may have the copies of that STC and send them to you via email. Bob
Old June 24th 19, 02:30 PM posted to rec.aviation.soaring
RV 6 Driver
Excellent idea. Now that you mention it I remember he helped me with another STC a few years ago. Thanks for the tip! Why didn't I think of that?
Old June 24th 19, 08:40 PM posted to rec.aviation.soaring
Jj
6:30 AM! Somethings wrong.
Old June 25th 19, 07:29 PM posted to rec.aviation.soaring
RV 6 Driver
Hi Bob,
I spoke with Dan this morning. He knows a lot about these STC's. Unfortunately thought he does not have access to the installation instructions. Is there any way you could send me a picture of the way you have yours installed?
Thanks
Old June 25th 19, 09:44 PM posted to rec.aviation.soaring
Bob Youngblood
Sure, there are a couple of different cooler installation types, give me a call, 772-453-Nine999
Old June 28th 19, 12:08 AM posted to rec.aviation.soaring
You might give Yorkton Air Service http://yorktonaircraft.com/ a shout in Saskatchewan Canada. They do a lot of work with older Pawnees.
Old June 30th 19, 04:05 PM posted to rec.aviation.soaring
RV 6 Driver
Thanks
I'll give them a call Monday,
Piper PA-25 Pawnee pics [04/11] - Pawnee pulls a glider.jpg (1/1) Miloch Aviation Photos 0 November 10th 18 03:53 PM
Piper PA-25 Pawnee pics [03/11] - PA-25-235 Pawnee C at the Celje Airport.jpg (1/1) Miloch Aviation Photos 0 November 10th 18 03:53 PM
Piper PA-25 Pawnee pics [02/11] - early pawnee.JPG (1/1) Miloch Aviation Photos 0 November 10th 18 03:53 PM
Piper PA-25 Pawnee pics [01/11] - A Swift glider is performing continuous full rolls while being towed by a Pawnee.jpg (1/1) Miloch Aviation Photos 0 November 10th 18 03:53 PM
auxiliary heat Jim Burns Owning 15 October 20th 04 09:08 PM
