Oudie2 connection to LXnav V7
Old October 15th 14, 01:31 PM posted to rec.aviation.soaring
John Docherty[_2_]
Default Oudie2 connection to LXnav V7
I've connected my Oudie2 to LXnav V7 with cable supplied but no information
is transferred to the LXnav. I setup to receive data from PDA and have
checked menu on Oudie and V7 but still no data. Can anyone help.
Old October 15th 14, 02:47 PM posted to rec.aviation.soaring
On the Oudie in the Menu Settings Hardware screen
Device: LXNAV V7
GPS Forwarding: enabled
Use backup GPS: disabled (may not be necessary)
Port Settings
Com4, 115200
On the V7 in the Communications screen
GPS-PDA Link: disabled
Auto Baudrate: disabled
PDA Port baudrate: 115200
GPS port baudrate: 115200
Old October 16th 14, 12:48 AM
dbrunone dbrunone is offline
Member
First recorded activity by AviationBanter: Oct 2011
If I'm not mistaken, you need a special cable to do this, I don't think the stock cable included with the Oudie will work. You need part CC-NP-Oudie http://www.cumulus-soaring.com/lxnav.htm#CC-NP-Oudie
Old October 16th 14, 07:34 AM posted to rec.aviation.soaring
Naviter Info
This works if Oudie is to be used as your GPS source for the V7 and no other GPS is connected to the back of the V7.
If the GPS source for the V7 is an external GPS (Flarm, Nano, whatever) then these settings will work best:
GPS Forwarding: disabled (this is quite important)
Use backup GPS: enabled (not so important but backup is backup)
Regards,
Andrej Kolar
glider pilots use
http://www.naviter.com
Device: LXNAV V7
Port Settings
Com4, 115200
Old October 16th 14, 02:27 PM posted to rec.aviation.soaring
Richard[_9_]
Cable also available at
http://www.craggyaero.com/lxnav_varios.htm
Richard
Oudie2 - V7 - PowerFlarm Core setup (cabling question) ES Soaring 4 March 3rd 14 12:29 AM
New Naviter Oudie2 Lite Paul Remde Soaring 0 December 7th 12 03:26 AM
Oudie2 Units in Stock Paul Remde Soaring 0 August 30th 12 03:14 PM
Oudie2's available again in the USA - Upgrades also available Paul Remde Soaring 0 August 20th 12 09:32 PM
Oudie2 units now shipping Paul Remde Soaring 3 April 30th 12 08:51 PM
