Alisha's Addict wrote in message . ..
On Tue, 25 May 2004 22:22:43 +0100, "Ian" wrote: "Eric Moore" wrote in message m... It looks like the F-22 isn't the only aircraft with teething problems. See: http://www.spacewar.com/2004/040524222142.i5vufze7.html Anyone care to speculate on how long it will take de-bug this aircraft? SNIP: Dump Windows XXX and go to Linux? Who knows, but at least no more screen of blue death. Walt BJ |
"Paul F Austin" wrote in message ... "Ian" wrote in message ... "Eric Moore" wrote in message ... It looks like the F-22 isn't the only aircraft with teething problems. See: http://www.spacewar.com/2004/040524222142.i5vufze7.html Anyone care to speculate on how long it will take de-bug this aircraft? Can't get the URL to work properly on my machine, but if its the report I think it is, a lot of the issues have either gone away (were just arguing over the phrases some release documents used) or are only as a result of the so called independent assessors (who were funded by the MoD!!!) not really liking the UK prime company. Funny how all four partner countries have the same flight control software, yet only the UK are "unhappy" If they're that unhappy with it, how come a pair of the RAF jets have just flown over my house?? That may be the case for most of the bugs cited by QinetiQ but some are serious: "Corruption" of the flight control computer system means that it could suddenly switch from "in-flight" mode to "ground" mode in mid-air, leading to "immediately catastrophic" results. and The cockpit flight information displays "frequently fail in flight", and therefore, whenever a Eurofighter is taken into cloud or bad weather, it should again be with two pilots. sound quite serious, although I don't know how a second pilot will help in the second case. The corruption of the FCC was never a real issue - it was more to do with the way the testing was reported. Funny thing is, the tests that were performed were to a QinetiQ spec. Funnily enough the spec was never questioned by anybody outside BAe who had concerns that it wasn't the right thing. As far as I know the "frequent" cockpit display failures means two in a development fleet just over 10 years old. Suppose 1 every five years is frequent! Hasn't stopped them flying the things from Warton where its normally cloudy (although havent seen that many clouds over teh last few weeks!) |
On Tue, 25 May 2004 23:01:01 -0400, (Peter
Stickney) wrote: snip wouldn't "corruption" mean a faulty hard drive/memory unit that just needs to be replaced? Surely that could be done a small amount of time although can't see the point of the RAF cranking out so many two-seater Tffies for training purposes. whats the point of buying the advanced version of the Hawk then if their wasting money on pricey trainer version of the typhoon? It's unlikely to be a hard drive. (There shouldn't be one at all, for a system like that) Corruption, in the Real TIme System context, such as a Flight Centrol System, ir Data Acq, or other such, menas that the program is stomping all over its volatile data. In other words, the airplane doesn't know where it it, what it has done, or what it's doing now. If you know teh systems, and can read teh clues, it can be even worse than that. Many real time systems copy their inital programs & state from non-volatile storage (Prom, Eprom, or EEprom, or possibly Flash) to RAM to actually run. (Far better access times with RAM). in that case, it's entire possible for the system to stomp all over the running program, as well. (Fandango on Core) wiping all of teh current state out. Having this happen in flight would be Very, Very, Very Bad. Heres a portion of the executive summary:- "1.4 Landing Gear Computer 1.4.1 At least twelve failures of the Landing Gear Computer (LGC) have occured since it was productionised for Series Production Aircraft. Although modifications to the LGC were introduced following initial failures, a number of subsequent failures have occurred. These failures have been unpredictable, and have caused incidents whereby aircraft have had invalid Landing Gear indication and/or loss of braking. Recommendations to reduce the impact of invalid Landing Gear indication and loss of braking have been provided. 1.4.2 It is believed by industry that the problems lie with Electronic Programmable Logic Devices (EPLDs) inside the LGC; however, the causes of the failure are not fully understood. Multiple failures of these ELPDs may cause a corruption of the Nose, and the Left or Right Weight on Wheels (WoW) Solid State Relays (SSR). There remains an unquantified risk that the SSRs’ corruption could result in a change in Flight Control System status from FLIGHT to GROUND, which would be immediately catastrophic. There is no feasible practical mitigation for such an event, making it UNACCEPTABLE. 1.4.3 It is therefore recommended as ESSENTIAL that the LGC failure modes are investigated, understood, and, if necessary, rectified before release to service. " Cheers John Cook Any spelling mistakes/grammatic errors are there purely to annoy. All opinions are mine, not TAFE's however much they beg me for them. Email Address :- Spam trap - please remove (trousers) to email me Eurofighter Website :- http://www.eurofighter-typhoon.co.uk |
On Tue, 25 May 2004 17:38:41 -0400, Paul F Austin wrote:
That may be the case for most of the bugs cited by QinetiQ but some are serious: "Corruption" of the flight control computer system means that it could suddenly switch from "in-flight" mode to "ground" mode in mid-air, leading to "immediately catastrophic" results. and The cockpit flight information displays "frequently fail in flight", and therefore, whenever a Eurofighter is taken into cloud or bad weather, it should again be with two pilots. sound quite serious, although I don't know how a second pilot will help in the second case. The impression I get is that the fault is a software bug rather than hardware corruption. It's not as if they're using a dodgy cheapo hard disk to store it on! -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (Email: zen19725 at zen dot co dot uk) |
"phil hunt" wrote in message rg... On Tue, 25 May 2004 17:38:41 -0400, Paul F Austin wrote: That may be the case for most of the bugs cited by QinetiQ but some are serious: "Corruption" of the flight control computer system means that it could suddenly switch from "in-flight" mode to "ground" mode in mid-air, leading to "immediately catastrophic" results. and The cockpit flight information displays "frequently fail in flight", and therefore, whenever a Eurofighter is taken into cloud or bad weather, it should again be with two pilots. sound quite serious, although I don't know how a second pilot will help in the second case. The impression I get is that the fault is a software bug rather than hardware corruption. It's not as if they're using a dodgy cheapo hard disk to store it on! I agree. I have the same impression. If the FCS goes TU in an aircraft that's statically unstable in pitch for instance, the results would be "immediately catastrophic" |
Similar Threads | ||||
Request: Technical Proofreading EAA Sport Aviation | Jim Weir | Home Built | 31 | July 20th 04 05:15 PM |
F22 Problems | Paul F Austin | Military Aviation | 9 | February 5th 04 02:27 AM |
Eurofighter weapon load mystery | John Cook | Military Aviation | 2 | January 27th 04 10:01 PM |
Shock news EUROFIGHTER to be axed in RAF program changes. | Aerophotos | Military Aviation | 11 | November 10th 03 08:55 PM |
Eurofighter is turning into German nightmare | Chad Irby | Military Aviation | 45 | October 4th 03 03:18 AM |
