#51
Pitot/static leak issues when using a "squat switch"
Darryl Ramm wrote on 11/30/2019 10:13 PM:
On Saturday, November 30, 2019 at 7:30:25 PM UTC-8, Mike Schumann wrote: On Saturday, November 30, 2019 at 8:26:42 AM UTC-6, Eric Greenwell wrote: Darryl Ramm wrote on 11/29/2019 10:36 PM: Again if you are installing TABS just set the transponder squat switch to "None" and use manual ON/ALT switching on the transponder. I might forget to switch it correctly. Would using the "gear is down" switch to change between ground/airborne be a sensible choice? The pattern (and the first 500'-1000' after the takeoff) would be flown showing the glider was on the ground, of course, but that might be better than having the whole flight showing as on the ground. If you use a squat switch with a Trig transponder, I believe that also puts the Transponder into GRND mode, so it wouldn't be responding to interrogations. The one place you do want ADS-B OUT and your transponder operating is in the pattern. That's where half of the midairs occur. Turning off ADS-S B OUT or your transponder as soon as you lower the gear is a really bad idea. Mike has an important point. Please do not dick around and end up disabling a safety system. If you are in the air the transponder needs to be in ALT mode. What is actually going on is a bit more messy, but "not responding to interrogations" is a useful summary. In GND mode Mode-S transponders will actually reply to direct addressed Mode-S interrogations, and do some other things, but that a far from a necessary set for the transponder to operate normally (e.g. it can't be acquired as a target by SSR). It will keep transmitting ADS-B Out, but messages encode the glider is on the ground, and some message content changes slightly. How all different ADS-B receivers all respond to that is uh anybody's guess. I just have an image in my mind of somebody seeing a transponder reply LCD thingy blink when in GND mode at some time and say "ha see it's replying OK". Ah nope, it's replying to a small subset of stuff. Flying in GND mode is a bad idea. I thought it might be a bad idea, but it was easy to do, so worth asking. When I do a TABS install, I will use an airspeed sensor - easy and cheap enough. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
#52
Since I started flying in 1973 REAL MEN (:-D) manually switched their
transponders from Off to STBY to ON, then from OFF to STBY to ON to ALT, then from OFF to STBY to On to GND to ALT.Â* Now all you weenies need to have a "system" to do it for you. Is the switch count too high?Â* I guess the next thing you'll all need is instant coffee or beer in cans... Happy December!Â* Winter is just three weeks away. On 12/1/2019 7:54 AM, Eric Greenwell wrote: Darryl Ramm wrote on 11/30/2019 10:13 PM: On Saturday, November 30, 2019 at 7:30:25 PM UTC-8, Mike Schumann wrote: On Saturday, November 30, 2019 at 8:26:42 AM UTC-6, Eric Greenwell wrote: Darryl Ramm wrote on 11/29/2019 10:36 PM: Again if you are installing TABS just set the transponder squat switch to "None" and use manual ON/ALT switching on the transponder. I might forget to switch it correctly. Would using the "gear is down" switch to change between ground/airborne be a sensible choice? The pattern (and the first 500'-1000' after the takeoff) would be flown showing the glider was on the ground, of course, but that might be better than having the whole flight showing as on the ground. If you use a squat switch with a Trig transponder, I believe that also puts the Transponder into GRND mode, so it wouldn't be responding to interrogations.Â* The one place you do want ADS-B OUT and your transponder operating is in the pattern.Â* That's where half of the midairs occur. Turning off ADS-S B OUT or your transponder as soon as you lower the gear is a really bad idea. Mike has an important point. Please do not dick around and end up disabling a safety system. If you are in the air the transponder needs to be in ALT mode. What is actually going on is a bit more messy, but "not responding to interrogations" is a useful summary. In GND mode Mode-S transponders will actually reply to direct addressed Mode-S interrogations, and do some other things, but that a far from a necessary set for the transponder to operate normally (e.g. it can't be acquired as a target by SSR).Â* It will keep transmitting ADS-B Out, but messages encode the glider is on the ground, and some message content changes slightly. How all different ADS-B receivers all respond to that is uh anybody's guess.Â* I just have an image in my mind of somebody seeing a transponder reply LCD thingy blink when in GND mode at some time and say "ha see it's replying OK". Ah nope, it's replying to a small subset of stuff. Flying in GND mode is a bad idea. I thought it might be a bad idea, but it was easy to do, so worth asking. When I do a TABS install, I will use an airspeed sensor - easy and cheap enough. -- Dan, 5J |
#53
In 1973, I was such a real man, I didn't even HAVE a transponder! Now, I'm no
longer a "Real Man", I'm a "Real Old Man", and the less I have to remember, the less I forget. Also, in 1973 I didn't have a flight computer, Flarm, inReach, or a motor clogging my memory. Also glad I don't have to remember to hook up the controls correctly - really glad about that. :^) Dan Marotta wrote on 12/1/2019 7:50 AM: Since I started flying in 1973 REAL MEN (:-D) manually switched their transponders from Off to STBY to ON, then from OFF to STBY to ON to ALT, then from OFF to STBY to On to GND to ALT.* Now all you weenies need to have a "system" to do it for you. Is the switch count too high?* I guess the next thing you'll all need is instant coffee or beer in cans... Happy December!* Winter is just three weeks away. respond to that is uh anybody's guess.* I just have an image in my mind of somebody seeing a transponder reply LCD thingy blink when in GND mode at some time and say "ha see it's replying OK". Ah nope, it's replying to a small subset of stuff. Flying in GND mode is a bad idea. I thought it might be a bad idea, but it was easy to do, so worth asking. When I do a TABS install, I will use an airspeed sensor - easy and cheap enough. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
#54
On Sunday, December 1, 2019 at 7:51:01 AM UTC-8, Dan Marotta wrote:
Since I started flying in 1973 REAL MEN (:-D) manually switched their transponders from Off to STBY to ON, then from OFF to STBY to ON to ALT, then from OFF to STBY to On to GND to ALT.Â* Now all you weenies need to have a "system" to do it for you. Is the switch count too high?Â* I guess the next thing you'll all need is instant coffee or beer in cans... Happy December!Â* Winter is just three weeks away. On 12/1/2019 7:54 AM, Eric Greenwell wrote: Darryl Ramm wrote on 11/30/2019 10:13 PM: On Saturday, November 30, 2019 at 7:30:25 PM UTC-8, Mike Schumann wrote: On Saturday, November 30, 2019 at 8:26:42 AM UTC-6, Eric Greenwell wrote: Darryl Ramm wrote on 11/29/2019 10:36 PM: Again if you are installing TABS just set the transponder squat switch to "None" and use manual ON/ALT switching on the transponder. I might forget to switch it correctly. Would using the "gear is down" switch to change between ground/airborne be a sensible choice? The pattern (and the first 500'-1000' after the takeoff) would be flown showing the glider was on the ground, of course, but that might be better than having the whole flight showing as on the ground. If you use a squat switch with a Trig transponder, I believe that also puts the Transponder into GRND mode, so it wouldn't be responding to interrogations.Â* The one place you do want ADS-B OUT and your transponder operating is in the pattern.Â* That's where half of the midairs occur. Turning off ADS-S B OUT or your transponder as soon as you lower the gear is a really bad idea. Mike has an important point. Please do not dick around and end up disabling a safety system. If you are in the air the transponder needs to be in ALT mode. What is actually going on is a bit more messy, but "not responding to interrogations" is a useful summary. In GND mode Mode-S transponders will actually reply to direct addressed Mode-S interrogations, and do some other things, but that a far from a necessary set for the transponder to operate normally (e.g. it can't be acquired as a target by SSR).Â* It will keep transmitting ADS-B Out, but messages encode the glider is on the ground, and some message content changes slightly. How all different ADS-B receivers all respond to that is uh anybody's guess.Â* I just have an image in my mind of somebody seeing a transponder reply LCD thingy blink when in GND mode at some time and say "ha see it's replying OK". Ah nope, it's replying to a small subset of stuff. Flying in GND mode is a bad idea. I thought it might be a bad idea, but it was easy to do, so worth asking. When I do a TABS install, I will use an airspeed sensor - easy and cheap enough. -- Dan, 5J Let's have Boeing design a system to keep gliders from stalling too. I am with Dan on this one. For almost 7k hours I have been turning my transponder to alt before takeoff and turning to stby once clear of runway. Like I need something else in my life that can break. It is hard to break a habit, trust me from the bucket of bad habits. |
Similar Threads | ||||
Are air filters necessary on Pitot, static or TE lines? | Pete[_9_] | Soaring | 15 | December 18th 18 02:13 AM |
Pitot Static 411 413 followup post | A Lieberman | Owning | 12 | June 18th 05 04:00 PM |
My static system had a leak | Derrick Early | Instrument Flight Rules | 1 | August 25th 04 02:35 PM |
pitot/static location | Ray Toews | Home Built | 2 | December 30th 03 12:52 AM |
Pitot and static couplings for a TTU-205 | B2431 | Home Built | 0 | August 15th 03 07:25 AM |
