Moving map query
Old September 6th 03, 10:51 AM
Martin Gregorie
Default Moving map query
Has anybody used SoaringPilot on a Palm m100?
If so:
- what are its pros and cons?
- how does the m100 display readability compare with an IPAQ 3630 or
3850 in the cockpit?
TIA,
Martin
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
Old September 6th 03, 05:22 PM
bsquared
That's what I'm using. I've found the readability to be fine. I can't
compare it to the IPAQ because I've never seen one in operation.
The pros: it was inexpensive and easy to connect to the GPS (Garmin eTrex
Venture). It has a lot of capability.
The cons: slow processor and the capacitor that holds the memory while you
change the batteries goes bad so there is a good chance that you will lose
any saved flights and loaded programs each time you change the batteries.
Bsquared
"Martin Gregorie" wrote in message
If so:
TIA,
Martin
demon :
uk :
Old September 6th 03, 06:02 PM
Pete Brown
Martin:
A good place to make this inquiry is :
http://groups.yahoo.com/group/soaringpilot/
This is a site dedicated to Soaringpilot user questions.
Peter D. Brown
http://home.gci.net/~pdb/
http://groups.yahoo.com/group/akmtnsoaring/
Marc Ramsey
"Martin Gregorie" wrote...
If so:
I've run SoaringPilot on an m100, and have also run homebrew software on an m100
and an iPAQ 3950. The m100 doesn't quite have enough processing power to drive
a moving map, so I primarily used it for textual displays (final glide, etc.).
The m100 display has far more contrast than the iPAQ or other color PDAs. It is
quite readable in the cockpit under almost any lighting condition, except near
sunset.
The iPAQ screen is great indoors, but marginal in the cockpit. Under direct
sun, there isn't enough contrast for my nearing 50 year-old eyes, plus glare
becomes a problem at certain sun angles (a good screen protector helps). It's
difficult to distinguish colors, and I'm constantly fiddling with the colors I
use to improve the readability. The 3630 and 3850 do have the older reflective
displays, which are a bit more readable in direct sunlight.
Marc
Old September 7th 03, 10:00 AM
Martin Gregorie
On Sat, 06 Sep 2003 17:02:23 GMT, "Marc Ramsey"
If so:
sunset.
Thanks for the analysis. FWIW if I go the IPAQ way I'll run XCSoar,
which has an uncluttered, essentially black & white display which
would presumably sort out some of the contrast problems.
It seems that all the PDAs I know about have problems:
- no external power connection for the Palm m100 and slow
- Compaq Aero 1500 displays fade out in a sunlit cockpit
as they get hot
- IPAQ 3630 and 3850 get hot and crash in a sunlit cockpit.
Are there any other WinCE PDAs I should be looking at?
I'm primarily interested in using a PDA system to display a moving map
for general navigation and restricted airspace avoidance.
demon :
uk :
Old September 7th 03, 10:42 AM
Marc Ramsey
You can live without external power, I used NiMH rechargeables, and could easily
get 7 or 8 flying hours per charge. It is slow, though...
as they get hot
True, but keep a white cloth or hat over it until takeoff, and it will be fine.
My 3950 has never crashed due to heat, even when the temperature exceeds 40C on
the ramp. The screen is also unaffected.
The Axim is inexpensive, but finding an appropriate mount may still be a
problem.
The upcoming replacement for the low-end Palm Zire interests me. It allegedly
has a decently fast ARM processor running PalmOS 5, 8 mb of memory (instead of
2), an external power jack, and a high contrast monochrome screen like the m100.
The main problem is likely to be finding a way to get GPS data into the thing...
Marc
Old September 7th 03, 10:42 PM
jerome
I use SoaringPilot on a M105 since 2 years, and I am very happy with
it.
If you keep the number of SUA data at minimum, the moving map is very
usable (about 2/3 s refresh time with Afterburner at 24MHz). With
cheap disposable batteries, I get about 10 flight hours: more than
sufficient -even for me!- for a 500km task.
For the battery change problem, I have a good solution: get a 3v
button size battery, 2 thin copper blades attached to each side with
insulating tape and inserted behind the battery contacts while
changing the batteries!
I use SP with a small mouse-shaped Deluo GPS, wich is very convenient.
Have a good flight!
AVIATIONTOOLBOX: moving map script (was PocketEfis & PalmEfis) Darrel Toepfer General Aviation 0 August 11th 04 01:34 PM
Navzilla Moving Map Software for iPAQs and Laptops Navzilla Team Piloting 1 May 22nd 04 10:10 PM
Navzilla Moving Map Software for iPAQs and Laptops Navzilla Team Aviation Marketplace 0 May 20th 04 03:01 AM
Moving Map on IPAQ Bob Simulators 0 March 25th 04 09:30 PM
Engine moving day... Gene Z. Ragan Home Built 2 March 16th 04 01:26 AM
