question about instrument proficiency check
Old October 19th 05, 01:55 PM
Bill Zaleski
Default question about instrument proficiency check
On Wed, 19 Oct 2005 08:27:06 -0400, Ron Rosenfeld
On Tue, 18 Oct 2005 19:36:41 -0700, Sylvain wrote:
Ron Rosenfeld wrote:
So it seems this is another area of Lynch's FAQ's that should be changed.
...or may be it is part 61 that needs some rewrite...
ok, now, I am getting confused (well, a little bit more than I was
already that is :-) ); is there any examiner reading this?
what would be the answers to these questions (privileges of flight and
ground instructors) least likely to have someone fail a CFI checkride?
--Sylvain
I would think that if OK city is teaching at an Examiner's training session
that an IGI cannot give an FPC in an FTD, & that Lynch's FAQ's say they
can, that something needs to be changed.
I did point all this out in my email to Lynch.
Think about it......The FAA is not going to let a non-pilot, non
flight instructor, (the ground instructor ratings require neither),
that just may have never even been in an aircraft himself, to certify
that a pilot is fit to go up in the crap. Do you think otherwise?
Old October 19th 05, 07:00 PM
Sylvain
Absolutely not. But the discussion was not about common sense here,
but rather the strict interpretation of the scriptures as they stand.
--Sylvain
Old October 19th 05, 08:34 PM
Bill Zaleski
--Sylvain
Well, then you seem to have answered the question about who you would
use for an IPC.
Old October 19th 05, 08:46 PM
Ron Rosenfeld
On Tue, 18 Oct 2005 22:27:14 -0400, Ron Rosenfeld
On Wed, 19 Oct 2005 01:34:56 GMT, Bill Zaleski
On Tue, 18 Oct 2005 20:45:29 -0400, Ron Rosenfeld
On Tue, 18 Oct 2005 21:51:25 GMT, Bill Zaleski
I can't find that statement specifically in the regs, although in John
Lynch's FAQ's regarding Part 61,
thanks a bunch! I feel silly not to have looked for it in
the FAQ first (the fact that there is an entry in the
FAQ on this very subject would tend to show that the regs
by themselves are a wee bit ambiguous :-) )
--Sylvain
A ground instructor can give the training, but cannot sign off an IPC.
Sounds a little strange, but true. Only a CFII can endorse the IPC.
This information was taught at Oklahoma City during the initial pilot
examiner certification course. You can look at FAR 61.215 and see
that it is not included within the priveliges afforded ground
instructors.
How about if the IPC is given in a sim?
Doesn't change anything. A ground instructor's priveliges are
specified in 61.215. Endorsing an IPC is not one of them.
OK -- now I have to go back and try to find what I was vaguely remembering
That's contrary to what Lynch writes in Q&A315
"... The term "authorized instructor" was intentionally used in § 61.57(d)
because authorization to conduct an instrument proficiency check is not
limited to a CFII. A Ground Instructor Certificate - Instrument Rating is
also an "authorized instructor" and is authorized to give the instrument
proficiency check in an approved flight training device."
Lynch also lists some other, non-CFII types that are authorized to give
IPC's under certain circumstances.
Having written that, I agree with you that 61.215(c) is contrary to what
Lynch writes in that it mentions only the "training" and if the FAA wanted
to allow IGI's to give IPC's in FTD's, they could have specifically so
stated in that section.
But let me check the most recent version -- the one I was looking was 2003.
Nope -- unchanged in 2005. I'll send him an email.
"onward through the fog"
Bill, and Sylvain,
I sent my email to Mr. Lynch yesterday and received his response today.
The answer in Q&A-315 *IS incorrect* and will be changed in the next
published revision. In particular, the change will specifically state that
an IGI is *NOT* authorized to administer an IPC.
Old October 20th 05, 09:11 AM
nooks!!
hello there!. this one might be useful,
http://www.tpub.com/aviation1.htm
try to visit the link. they provide military aviation infos there!
Sylvain wrote:
Until recently I was convinced that only a CFII could
conduct an instrument proficiency check (as opposed
to a plain CFI), but now I am confused:
14 CFR 61.195(c) says that an instructor must have an
instrument rating on *both* his pilot and instructor
certificates, i.e., be a CFII, in order to "provide(s)
instrument flight training *for the issuance of an
instrument rating*";
This is how a plain CFI (not II) can provide the training
required to satisfy the requirements of good old
14 CFR 61.109(a)(3) -- i.e., the three hours training
by sole reference to instruments required to get a
private certificate;
Now, the problem is that I haven't found where in the
regulations it is specified that a CFII must conduct
the instrument proficiency check (which is *not* training
for the issuance of an instrument rating that the student
already has); 14 CFR 61.57(d) says training has to be
provided by an 'authorized instructor' (in addition to
examiners etc.) -- is this what I am missing? that
would be an odd use of the term 'authorized instructor'
as compared to other places in the regs.
Now I probably missed something obvious, but can a
CFI (not II) provide the training and endorse someone's
instrument proficiency check? (and if not where is it
said in the regs?)
Note: I am not trying to do something silly, but
I am in the process of studying the regs in details
and I like to understand the fine points.
--Sylvain
Bank/turn indicator instrument question Bruce W.1 Home Built 10 February 17th 05 04:14 PM
Instrument mounting question Rob Turk Home Built 4 July 19th 04 10:33 PM
Instrument Question Dick Home Built 10 May 30th 04 12:05 AM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
Use of hand-held GPS on FAA check ride Barry Instrument Flight Rules 1 August 9th 03 09:25 PM
