Drone Pilot Settles With FAA Over Video Flight
On Sun, 25 Jan 2015 08:35:20 +1300, george152 wrote:
On 25/01/2015 4:04 a.m., Larry Dighera wrote: My personal experience encountering an unresponsive Predator at 8,500', 12 o'clock and five miles while operating on a flight plan en route from KLAS to KSBA is what galvanized my opinion of drone operations within the NAS. There was no chase aircraft observing the drone (required), and the operator failed to answer repeated radio calls from Joshua Approach Control, causing me to divert my flight path to avoid the unresponsive drone. This nonchalant attitude of drone operators is the heart of the UAS issue, and the arrogance of the drone manufacturers is amazing, not to mention the apathy of airline passengers. Is there any chance we can stop calling them pilots? They appear to be operators I hear you. However, FAA is attempting to mandate that UAS operators hold a valid airmans certificate: See: https://www.faa.gov/uas/faq/#qn9. https://www.faa.gov/documentlibrary/media/notice/n_8900.227.pdf "b. Policy. Policy identifies Unmanned Aircraft (UA) as “aircraft” flown by a “pilot” regardless of where the pilot is located. Aircraft and pilots must demonstrate compliance with applicable sections of Title 14 of the Code of Federal Regulations (14 CFR) to operate in the NAS. However, UA are not compliant with certain sections of 14 CFR. For instance, the absence of an onboard pilot means that the “see-and-avoid” provisions of 14 CFR part 91, § 91.113, cannot be satisfied. Without an onboard pilot, there is a significant reliance on the command and control link, and a greater emphasis on the loss of functionality associated with lost link. Furthermore, for air traffic control (ATC) operations requiring visual means of maintaining in-flight separation [VMC], the lack of an onboard pilot does not permit ATC to issue all of the standard clearances or instructions available under the current edition of FAA Order 7110.65, Air Traffic Control. Consequently, to ensure an equivalent level of safety, UAS flight operations require an alternative method of compliance (AMOC) or risk control to address their “see-and-avoid” impediments to safety of flight, and any problems they may generate for ATC. In the future, permanent and consistent methods of compliance will be needed for UAS operations in the NAS without the need for waivers or exemptions." At some point, as you said, they will all get a wake up call, and the true hazard UAS' pose will be undeniably revealed in the grizzly results. Is there any possibility that some form of complaint could be made that, when the inevitable happens, those 'lawmakers' could be imprisoned and this new system explained to the sluggards ? Ha Ha. What makes you believe they would be able to comprehend it? :-( We lost a lot of local ATC here and as a result had a couple of midairs and a number of close calls. Where's "here?" |
On 26/01/2015 8:30 a.m., Larry Dighera wrote:
On Sun, 25 Jan 2015 08:35:20 +1300, george152 wrote: On 25/01/2015 4:04 a.m., Larry Dighera wrote: My personal experience encountering an unresponsive Predator at 8,500', 12 o'clock and five miles while operating on a flight plan en route from KLAS to KSBA is what galvanized my opinion of drone operations within the NAS. There was no chase aircraft observing the drone (required), and the operator failed to answer repeated radio calls from Joshua Approach Control, causing me to divert my flight path to avoid the unresponsive drone. This nonchalant attitude of drone operators is the heart of the UAS issue, and the arrogance of the drone manufacturers is amazing, not to mention the apathy of airline passengers. Is there any chance we can stop calling them pilots? They appear to be operators I hear you. However, FAA is attempting to mandate that UAS operators hold a valid airmans certificate: See: https://www.faa.gov/uas/faq/#qn9. https://www.faa.gov/documentlibrary/media/notice/n_8900.227.pdf "b. Policy. Policy identifies Unmanned Aircraft (UA) as “aircraft” flown by a “pilot” regardless of where the pilot is located. Aircraft and pilots must demonstrate compliance with applicable sections of Title 14 of the Code of Federal Regulations (14 CFR) to operate in the NAS. However, UA are not compliant with certain sections of 14 CFR. For instance, the absence of an onboard pilot means that the “see-and-avoid” provisions of 14 CFR part 91, § 91.113, cannot be satisfied. Without an onboard pilot, there is a significant reliance on the command and control link, and a greater emphasis on the loss of functionality associated with lost link. Furthermore, for air traffic control (ATC) operations requiring visual means of maintaining in-flight separation [VMC], the lack of an onboard pilot does not permit ATC to issue all of the standard clearances or instructions available under the current edition of FAA Order 7110.65, Air Traffic Control. Consequently, to ensure an equivalent level of safety, UAS flight operations require an alternative method of compliance (AMOC) or risk control to address their “see-and-avoid” impediments to safety of flight, and any problems they may generate for ATC. In the future, permanent and consistent methods of compliance will be needed for UAS operations in the NAS without the need for waivers or exemptions." At some point, as you said, they will all get a wake up call, and the true hazard UAS' pose will be undeniably revealed in the grizzly results. Is there any possibility that some form of complaint could be made that, when the inevitable happens, those 'lawmakers' could be imprisoned and this new system explained to the sluggards ? Ha Ha. What makes you believe they would be able to comprehend it? :-( We lost a lot of local ATC here and as a result had a couple of midairs and a number of close calls. Where's "here?" New Zealand. In particular Paraparaumu and Fielding two fatals on circuit. I'll have to look up the accident reports |
On 26/01/2015 12:59 p.m., george152 wrote:
New Zealand. In particular Paraparaumu and Fielding two fatals on circuit. I'll have to look up the accident reports http://www.taic.org.nz/ReportsandSaf...Fskin_aviation and http://www.taic.org.nz/ReportsandSaf...Fskin_aviation And of course they know that it was the pilots fault as usual |
On Mon, 26 Jan 2015 13:15:52 +1300, george152 wrote:
On 26/01/2015 12:59 p.m., george152 wrote: New Zealand. In particular Paraparaumu and Fielding two fatals on circuit. I'll have to look up the accident reports http://www.taic.org.nz/ReportsandSaf...Fskin_aviation and http://www.taic.org.nz/ReportsandSaf...Fskin_aviation And of course they know that it was the pilots fault as usual Tragic indeed. Those accident reports sure do point out the limitations of see-and-avoid. And drone manufacturers in the US are insisting that the FAA permit them to intermingle their products with airline traffic within the National Airspace System WITHOUT being equipped with sense-and-avoid technology. It boggles the mind.... |
On 2/02/2015 10:45 a.m., Larry Dighera wrote:
Tragic indeed. Those accident reports sure do point out the limitations of see-and-avoid. And drone manufacturers in the US are insisting that the FAA permit them to intermingle their products with airline traffic within the National Airspace System WITHOUT being equipped with sense-and-avoid technology. It boggles the mind.... Yup. When you look at the size of a drone compared to the size of a C150.. Will it be necessary to equip light aircraft with a proximity RADAR system ? Not so much for airport traffic but ag flying, gliding and general aviation.. |
Similar Threads | ||||
DJI Phantom drone flight over grid at 2013 Caesar Creek Contest | Sean F (F2) | Soaring | 13 | August 15th 13 04:32 PM |
VFR flight to KMEI Flight Following with ATC comms - Video | Rik Brown[_4_] | Instrument Flight Rules | 3 | January 18th 09 07:38 PM |
VFR flight to KMEI Flight Following with ATC comms - Video | A Lieberma[_2_] | Owning | 0 | January 18th 09 01:34 AM |
Does anybody know a link to a real picture of the X-43 in flight sans Pegasus or better yet a video clip of the flight? | Scott Ferrin | Military Aviation | 0 | April 3rd 04 08:47 PM |
Fox settles with O'Grady | David Windhorst | Military Aviation | 0 | January 21st 04 10:16 PM |
