#21
"Paul F Austin" writes: "B2431" wrote in message ... (Andrew Sanders) These comments were in response to something Dan (B2431) said: 'Even if they hadn't started the war Nazi Germany would have been a major flop in the long run.' Not sure; they damn nearly did win the war, Define "damn near did win the war." The pigs had nowhere near enough naval capacity to invade the U.K. and nowhere near enough air cover to support any landings. Do a little research on Operation Sealion. So what did the dummies do when they realized they couldn't take England? They went east against the Soviet Union who were prepared to sacrifice huge numbers of people while withdrawing their industrial strength out of reach of the pigs. Even without U.S. support the Soviets would have eventually bled the pigs dry just through attrition. Do a little research on Operation Barbarosa. In both cases the Nazi pigs would have had to develop long range heavy bombers to prolong the war. There is no way they could have won the war without Stalin's swinery quitting followed by a prolonged rest and recupperation before taking on the UK again. None of this addresses the fact that the murderers would have run out of Jews to extract gold teeth from to sell to the Swiss. The Nazi economy was on life support throughout the war. They only lasted as long as they did because they could capture gold and sell it to the Swiss collaborators. The Nazis were unspeakable ****s. That said, they had several opportunities to_win_the war. The first opportunity failure was the pause outside the British perimeter around Dunkirk. The second and third (these are related) are failures to mobilize German industry in 1940-41 and the failure to integrate conquered Europe industrially to support German war production. The fourth was in attacking the USSR and having done_that_bit of idiocy, driving the Ukrainians and European Russians back into Stalin's arms. In The Germans mobilizing their industry further, earlier: I really don't think that this would have had any effect. The limiting factor in German industrial prosuction was access to raw materiels. They didn't have enough, and anything that was going to be imported from anywhere other than the Soviet Union, (After the Molotov-von Ribbentrop Pact) would have had to get past the Royal Navy. Yes, they could have grubbed Coal out of the ground in the Ruhr, and Iron from Czechosovakia, and a bit of Nickel, but any Bauxite/Aluminum, Cobalt, Molybdenum, Chromium, Rubber, or any of ampty-zillion other materials needed for 1940s Industry had to come from somewhere else. And they couldn't get it, even if, say, someone in South America wanted to sell it to them. They didn't have the Merchant Marine to haul it, or the Navy to escort it. The Germans had been cutting back on arms production since about 1936. They just didn't have the feedstocks. They were able to make improvements, when things started getting desparate. Some of that was in the area of reducing wastage in teh manufacturing processes - the Germans had a habit of over-machining stuff that just didn't need to be spit-polished, and their rough castings needed to have a lot of metal removed to make finished parts. Material quality was dodgy, at best. For example, metallurigal tests on the glacis (Front Slope) armor of Panthers recovered in Normandy revealed that the actual protection value of the aormor plate varied by about 30%. (ANd you can't tell teh difference by looking at them.) Not a Good Thing, if you happen to be one of the crews issued a lemon. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
Similar Threads | ||||
#1 piston fighter? | Peter Stickney | Military Aviation | 18 | July 12th 03 12:16 AM |
