FS: Vertex Standard VXA-210 Pilot handheld radio like new $225.00
I have a Vertex Standard VXA-210 Pilot w/SU-1 sensor for sale. It is in very
good condition with very little use. The battery is in great shape and the radio is ready to be put into service. This is a NAV/COM radio. I have pics available if for those that are interested. $225.00 plus shipping Cont. US only. Includes the following: Ni-Cad Battery Pack FNB-64 ( 7.2V 700 mAh ) Overnight Charger NC-77B/C Helical Antenna ATV-7 Headset Cable Adapter CT-60 Operating Manual Belt Clip Also included is the SU-1** Barometric Pressure Sensor. ($40.00 option) ------------------------------------------------------------------------ General Specifications VXA-210 Number of Channels 150 Channels Frequency Range TX Com: 118.000 - 136.975 MHz Frequency Range RX NAV: 108.000 - 117.975 MHz Frequency Range RX Com: 118.000 - 136.975 MHz Frequency Range WX: (WX-01 - WX-10) : USA version only Channel Spacing 25 KHz Emission Type TX: AM Emission Type RX: AM & FM Power Supply Voltage 6.0 - 15.0 VDC Current Consumption (approx.) 65 mA (squelch on) 190 mA (receive) 1 A (transmit 1.5 W Carrier) Ambient Temperature Range +14° F to + 140° F (-10° C to + 60° C) RF Input-Output Impedance 50 Ohms Dimensions (WxHxD): 2.3" x 4.3" x 1.18" w/FNB-64 (58 x 109 x 30 mm) Weight (approx.) 12 oz (340 g) with FNB-64, antenna, and belt clip Receiver Specifications Measurements made per EIA standard TIA/EIA-603 Circuit Type Double Conversion Super-heterodyne IFs 35.4 MHz and 450 KHz Sensitivity 0.8 u V (for 6 dB S/N with 1 kHz, 30 % modulation) Selectivity 8 kHz/-6 dB Adjacent Channel Selectivity 25 kHz/-60 dB Audio Output 400 m W @ 8 Ohms, 10 % THD Transmitter Specifications Measurement made per EIA standard TIA/EIA-603 Power Output V): 5.0 W PEP / 1.5 W (Carrier Power) Frequency Stability Better than ±10 ppm (+14 °F to +140 °F) Modulation System Low Level Amplitude Modulation Spurious Emission 60 dB below carrier Int. Microphone Type Condenser Ext. Mic Impedance 150 Ohms |
Radio is sold!
thnx |
Similar Threads | ||||
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
Can a Private Pilot tow gliders and get paid? | zatatime | Piloting | 3 | October 17th 04 01:35 AM |
Pilot Error? Is it Mr. Damron? | Badwater Bill | Home Built | 3 | June 23rd 04 04:05 PM |
Vertex VXA-150 Pro V handheld radio question | Alan Meyer | Soaring | 2 | April 24th 04 01:42 PM |
