Engine installation labor
Old January 11th 04, 01:55 AM
Rohit Fedane
Default Engine installation labor
I just had an factory overhauled engine installed in my Piper Cherokee 180.
The shop had given me an original estimate of 20 hours of labor, but when it
was done they billed me for 33 hours blaming it on problems they had with
various fittings that they had not expected. Does anyone have any experience
with engine install on similar aircraft and what is a reasonable amount of
labor ?
--Rohit
Old January 11th 04, 03:16 PM
Rich Badaracco
I worked with my mechanic back in October to reinstall my overhauled engine.
I also fly a Cherokee 180. We completed the work over a weekend and did not
work full days. Lycoming has an engine installation and labor guidebook
which if I recall correctly estimates the time to remove/install the engine
at 24 hours. http://www.lycoming.textron.com/supp...5/SSP875-1.pdf
Outside of needing to be a contortionist to get at some of the connections
it's not that tough a piece of work.
"Rohit Fedane" wrote in message
rvers.com...
180.
it
experience
labor ?
--Rohit
Old January 11th 04, 03:17 PM
JDupre5762
labor ?
Is this just for installation or for removal and reinstallation? If it is for
both I would say it is not unreasonable. Going on takes longer than coming
off. Problems with fittings are always possible. The classic one is an oil
quick drain fitting that was put on by a gorilla and ends up getting destroyed
on removal despite various attempts to ease it out normally. On installation
it is not uncommon even from the factory to have various plugs that take
fittings installed so tightly that eventually they have to be drilled out.
Then there are baffling repairs and the like as well.
John Dupre'
Photos of damage to J3 Cub propeller after new engine mount installation [email protected] Home Built 0 August 9th 04 09:32 PM
Photos of damage to J3 Cub propeller after new engine mount installation [email protected] Home Built 0 August 9th 04 09:31 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Engine Replacement Labor costs.... [email protected] Owning 10 November 20th 03 12:14 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
