Weigh scales
I sold my mechanical Ruggles weigh scales and now am trying some
digital automotive racing scales that are just a little more expensive. The scales I found are actually less expensive than normal racing scales but the real advantage is that they can be sold individually rather than a set of four. For my purposes I only need two (use bathroom scale on front wheel) and that brings the price down to about $500 for two digital scales compared to $310 for the mechanical Ruggles scale set. I tested the accuracy of the new digital scales and they seem to be accurate to the nearest pound thats quite better than Ruggles. You can see the scales at http://racing.centralcarolinascale.com/low-cost.htm Another place http://www.usedscales.com/ws_and_ps_race_car_scale.htm also sells them, but when they found out I was going to use them for aircraft, they went bezerk and would not sell them to me but insisted that I purchase more expensive ones. I tried to explain that I can possibly calibrate the cheaper ones (just like you calibrate a compass with a compass correction chart) but they were so caught up in superlatives and safety slogans they would not listen. Any two of you can get together and purchase a whole set for about $900 and split it. Thats only about $450 for digital aircraft scale set (plus one good bathroom scale). |
"abripl" wrote in message
Any two of you can get together and purchase a whole set for about $900 and split it. Thats only about $450 for digital aircraft scale set (plus one good bathroom scale). Or . . . you can find a pal who works for the gummint, who knows a pal in the motor pool, and borrow a set of portable truck scales. Your taxes at work! Rich S. |
In article .com,
"abripl" wrote: I sold my mechanical Ruggles weigh scales and now am trying some digital automotive racing scales that are just a little more expensive. The scales I found are actually less expensive than normal racing scales but the real advantage is that they can be sold individually rather than a set of four. For my purposes I only need two (use bathroom scale on front wheel) and that brings the price down to about $500 for two digital scales compared to $310 for the mechanical Ruggles scale set. I tested the accuracy of the new digital scales and they seem to be accurate to the nearest pound thats quite better than Ruggles. You can see the scales at http://racing.centralcarolinascale.com/low-cost.htm Another place http://www.usedscales.com/ws_and_ps_race_car_scale.htm also sells them, but when they found out I was going to use them for aircraft, they went bezerk and would not sell them to me but insisted that I purchase more expensive ones. I tried to explain that I can possibly calibrate the cheaper ones (just like you calibrate a compass with a compass correction chart) but they were so caught up in superlatives and safety slogans they would not listen. Any two of you can get together and purchase a whole set for about $900 and split it. Thats only about $450 for digital aircraft scale set (plus one good bathroom scale). One caveat on using scales: Make sure that the hangar doors are closed, so there are no stray breezes to interfere with the weighing. Stray breezes can cause as much as 10-15 lb weight errors per scale. A good test is to weigh the plane, then remove it from the scales and heck the "zero weight" indication. -- Remove _'s from email address to talk to me. |
You might try some of the gokart racing suppliers too. They use digital
scale systems for setup. "abripl" wrote in message oups.com... I sold my mechanical Ruggles weigh scales and now am trying some digital automotive racing scales that are just a little more expensive. The scales I found are actually less expensive than normal racing scales but the real advantage is that they can be sold individually rather than a set of four. For my purposes I only need two (use bathroom scale on front wheel) and that brings the price down to about $500 for two digital scales compared to $310 for the mechanical Ruggles scale set. I tested the accuracy of the new digital scales and they seem to be accurate to the nearest pound thats quite better than Ruggles. You can see the scales at http://racing.centralcarolinascale.com/low-cost.htm Another place http://www.usedscales.com/ws_and_ps_race_car_scale.htm also sells them, but when they found out I was going to use them for aircraft, they went bezerk and would not sell them to me but insisted that I purchase more expensive ones. I tried to explain that I can possibly calibrate the cheaper ones (just like you calibrate a compass with a compass correction chart) but they were so caught up in superlatives and safety slogans they would not listen. Any two of you can get together and purchase a whole set for about $900 and split it. Thats only about $450 for digital aircraft scale set (plus one good bathroom scale). |
digital scale systems for setup. The problem with go cart scales is their capacity limited to 500lb maximum each and their platforms are smaller/awkward. My main wheels are about 700lbs each. Unless you are talkin only ultralights. |
Similar Threads | ||||
Glider weighing scales | C AnthMin | Soaring | 0 | July 12th 04 06:53 AM |
Glider weighing scales. | Terence Beasley | Soaring | 2 | July 7th 04 04:14 AM |
Dutch Roll | SelwayKid | Piloting | 31 | June 19th 04 11:43 PM |
Aircraft Scales | Kyle Boatright | Home Built | 6 | June 19th 04 07:59 PM |
AVIATIONTOOLBOX: GeoTIFF chunks of conUS in several scales | Kyler Laird | General Aviation | 0 | January 4th 04 05:12 PM |
