battery power regulator
In article Tony V writes:
An advertisement in QST magazine caught my eye and I wonder if some one has used something similar to this in gliders(we don't need 25 Amps at 12 Volts): http://www.mfjenterprises.com/Produc...ctid=MFJ-4416B The idea is to keep the voltage supplied to your electrics constant even if the battery voltage drops to as low as 9 Volts (in the above example). Tony LS6-b "6N" You might want to read the reviews at http://www.eham.net/reviews/detail/7504 first. I would want to test it extensively on the ground before I tried one in an aircraft. Unfortunately, in looking for other products that do the same thing, the reviews I have found have been no better. Alan |
Similar Threads | ||||
Oshkosh Camping - Battery Power | Tom McQuinn | Owning | 3 | June 11th 07 12:19 AM |
Power setting table and best economy/best power... | xerj | Piloting | 29 | October 20th 05 02:44 AM |
$15 Regulator for Onboard PC | Jim Vincent | Soaring | 0 | July 14th 05 06:46 PM |
battery charger to get through Piper power port? | Kyler Laird | Owning | 16 | March 20th 05 12:08 AM |
Rectifier/Regulator | Bill | Home Built | 0 | November 13th 04 04:54 PM |
