Airbags
Over 80% of new GA aircraft come equipped with seatbelt airbags.
Is there a reason why they cannot or would not be practical for use in sailplanes? |
Airbags
On Sep 2, 9:00*pm, Mario wrote:
Over 80% of new GA aircraft come equipped with seatbelt airbags. Is there a reason why they cannot or would not be practical for use in sailplanes? Well, for one thing, they require an electrical system, lacking in many sailplanes, which can momentarily supply quite a high current to fire the airbags. Also, there is a separate airbag control box and its associated wiring and current draw which would need to dealt with, as well as panel space for a status indicator and presumably a test button and/or an arm/safe switch, which might be in short supply in a tight cockpit. Then of course there is the cost and weight. A properly fitted and adjusted 4- or 6-point harness is pretty effective on its own. Don |
Similar Threads | ||||
Has any of the seatbelt airbags saved any lives? | Darkwing | Piloting | 0 | September 8th 06 02:00 AM |
