On Mon, 16 Aug 2004 16:38:20 GMT, Roger Halstead
wrote: Which brings to mind the question: How does anyone in Michigan use a Mogas STC? Our gas is not labeled as to whether it contains Alcohol or not. The pump sticker only states, "Meets Michigan fuel standard (something or other) call this 800 number for specifics or complaints", or something to that effect. We have the same problem here in Alaska, since our fuel doesn't meet whatever ASTM specification the mogas STCs require. ================================================== == Del Rawlins-- Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ Remove _kills_spammers_ to reply |
"Cy Galley" wrote in message news:FkdUc.307087$JR4.216248@attbi_s54... The problem isn't the gaskets and o-rings. The real problem is alcohol is a weak organic acid and corrodes metals. ++++++++++++++++++++++++++++ Isn't it also true, that alcohol dissolves the lacquers built up in the tank and fuel system? Long story short, I got two loads of gasohol (in a row) in a large motor home, and the many hundreds of gallons of gas that had been run through it, and the many times where gas had been allowed to sit for long periods of time, had deposited a large amount of lacquer in the tank. The lacquer was nicely dissolved, then deposited in the large canister filter, until there was not enough gas flow to run it at much more than an idle. It sound like a scenario that could be closely imitated in an airplane. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.737 / Virus Database: 491 - Release Date: 8/11/2004 |
