Engine stumble followup
Old December 10th 05, 05:32 PM posted to rec.aviation.owning
Default Engine stumble followup
OK..
By "feel" there is a little looseness in the throttle valve
bushings in the carb.. we gona look further.
Thanks to all for some great thoughts/solutions.
Can anybody suggest some tests to confirm an intake system
leak that allows excess low DA air to lean the mix when the throttle
valve closes rapidly at high engine RPM?
What clearance should there be in the Throttle Valve bushings?
(if any)
Dave
Old December 10th 05, 11:51 PM posted to rec.aviation.owning
Low density altitude air?
Does this mean less than manifold pressure air?
Does this mean the intake manifold air is leaking out or leaking in?
Old December 11th 05, 02:48 AM posted to rec.aviation.owning
Yes...dense air requiring a richer mixture...
No..... higher thsn MP air pressure..
Leaking into the manifold when the throttle is closed quickly...
Dave
Old December 11th 05, 02:49 AM posted to rec.aviation.owning
Arrrrughhh!
Flew today, -5C as opposed to -8C...
Could not get it to stumble on throt retard.. Rich, lean, VERY lean,
Rt tank,Lt tank, Pump on/off.
I don't know whether to be disappointed or elated.
Looks like I gotta fly it some more...
Dave
On Sat, 10 Dec 2005 13:32:05 -0400, Dave
OK..
(if any)
Dave
Old December 11th 05, 03:52 AM posted to rec.aviation.owning
Don't panic if you can feel clearance in the throttle shaft bushings.
Any carb with some time on it will have clearance, and it will feel
excessive. I don't of any spec on the allowable clearance, though.
Instead try to compare it with some other engines. Expect maybe .010
inch looseness on a worn shaft.
Engine stumble, Thoughts? Dave Piloting 16 December 6th 05 04:18 AM
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
