#51
"David Megginson" wrote in message
et.cable.rogers.com... [...] So which of these points do you not consider when you are planning a VFR flight? - your condition - the aircraft's condition - the weather - facilities (such as airports and navaids) - airspace - NOTAMs Heh heh...maybe you didn't intend it as a straw man, but it's coming apart at the seams right now. How does "the weather" rate just a single lone mention? There are lots of things involved with "the weather" that simply aren't a consideration for VFR flight. Because other components of "the weather" will prevent you from ever running into them. When I plan a flight, the item you simply call "the weather" looks something like this for VFR: - winds - visibility - ceiling Thunderstorms are an issue, but they are easily avoided when flying VFR. They aren't part of the go/no-go decision unless there's a line of them creating winds, low ceilings, or visibility issues (and usually, all of the above), in which case they are covered by the existing items. For IFR, there are additional items in addition to the VFR items: - freezing level - cloud tops - thunderstorms Thunderstorms are MUCH more of an issue flying IFR, because there's no way to avoid them. Once you're in the cloud, you're at the whim of your routing. Rather than being something to be aware of and avoid during the flight, they become a reason to not make the flight at all. That is, they are part of the go/no-go decision in and of themselves, but only for IFR flight. This is a simplistic look at my preflight decision making, but I hope it illustrates what I'm trying to say. At the very least, it should show you why I think your single mention of "the weather" as if it's the same for IFR and VFR just doesn't make sense. Pete |
#52
Peter Duniho wrote:
So which of these points do you not consider when you are planning a VFR flight? - your condition - the aircraft's condition - the weather - facilities (such as airports and navaids) - airspace - NOTAMs How does "the weather" rate just a single lone mention? There are lots of things involved with "the weather" that simply aren't a consideration for VFR flight. Because other components of "the weather" will prevent you from ever running into them. Choose a level of abstraction: the aircraft's condition is at least as complex as the weather, for example, and requires as much time and consideration. In fact, I can break a single step like "check the engine," down into a posting so long that no one but the most pathetic antisocial shut-in will bother reading all the way to the end. Thunderstorms are MUCH more of an issue flying IFR, because there's no way to avoid them. Flying in IMC is a no-go with even occasional CB or TCU forecast along the route, unless you have a Stormscope or Strikefinder on board; even then, you don't want to launch into numerous CB or TCU, not to mention a squall line. On the other hand, that stuff is a danger VFR as well, and any VFR pilot who doesn't spend time looking at convective activity before flying probably doesn't deserve her or his license: you still have to consider how likely it is that you'll be able to see the rain and lightning in time, given the ceiling and vis. All the best, David |
#53
ble.rogers.com... Choose a level of abstraction: the aircraft's condition is at least as complex as the weather, for example, and requires as much time and consideration. True, but so what? Those things don't change depending on whether the flight is IFR or VFR, and so are irrelevant to this discussion (other than instrumentation required for IFR flight, of course). My point is not that the other elements can not be further refined, but that your list trivially ignores the differences between IFR and VFR decision making by hiding those differences in a single, vague item. Flying in IMC is a no-go with even occasional CB or TCU forecast along the route, unless you have a Stormscope or Strikefinder on board; even then, you don't want to launch into numerous CB or TCU, not to mention a squall line. That's mostly what I said. Though, in truth, "occasional CB" is most certainly NOT an automatic no-go for IFR flight, even without a Stormscope or Strikefinder. Lots of cumulonimbus clouds are completely benign, and there are elements to the weather forecast that let you know when they are and when they aren't. Even widely scattered thunderstorms aren't an automatic no-go. It depends on the terrain, your route, time of day, and what's on the weather station radar already. You certainly can simplify your life by deciding that anytime the forecast mentions cumulonimbus clouds, you stay on the ground. But that's the sort of thing that greatly reduces the utility of the instrument rating. If you'll recall, very early in my comments along this thread, I specifically differentiated between pilots who actually use their instrument rating, and those that don't really gain any significant utility through the rating. On the other hand, that stuff is a danger VFR as well, and any VFR pilot who doesn't spend time looking at convective activity before flying probably doesn't deserve her or his license: you still have to consider how likely it is that you'll be able to see the rain and lightning in time, given the ceiling and vis. But it's not a go/no-go decision issue. VFR, I want to know where thunderstorms are, so that I can avoid them. But if the thunderstorms cause me to cancel the flight, it's because there's something else (like reduced visibility, high winds or turbulence, low ceilings, or all of the above). The simple presence of a thunderstorm doesn't cause the flight to be canceled, and is not part of what I'd call the "go/no-go decision". Contrasting to the IFR decision making, where the exact nature of the forecast, predicted thunderstorms, existing conditions, air stability and the like are all important, when flying VFR all that's really important is that you can see well enough to maintain a wide berth from any existing thunderstorms and to know when they block your path of flight completely (i.e. there's no detour to take you around). It's much more cut and dried than for IFR flight. Pete |
#54
Peter Duniho wrote:
You certainly can simplify your life by deciding that anytime the forecast mentions cumulonimbus clouds, you stay on the ground. But that's the sort of thing that greatly reduces the utility of the instrument rating. If you'll recall, very early in my comments along this thread, I specifically differentiated between pilots who actually use their instrument rating, and those that don't really gain any significant utility through the rating. That's why I've been having a Stormscope installed in my plane. I do not feel that I can responsibly fly through IMC when there's a forecast chance of embedded CB -- it's playing Russian roulette with my passenger's lives, and mine. I was recently reading an accident report from a few years ago when ATC vectored an entire family in a Cessna 210 (if I recall correctly) over Quebec right into a thunderstorm that didn't show up on ATC's radar. The plane broke up in flight. The pilot was an airline pilot flying his family to Prince Edward Island for their summer vacation, so he probably knew all the tricks about CB, but didn't, unfortunately, have a Stormscope, Strikefinder, or weather radar on board to back up his hunches and ATC's radar returns. But it's not a go/no-go decision issue. VFR, I want to know where thunderstorms are, so that I can avoid them. But if the thunderstorms cause me to cancel the flight, it's because there's something else (like reduced visibility, high winds or turbulence, low ceilings, or all of the above). That sounds pretty complicated to me -- at least as complicated as IFR flight planning. As you wrote, you have to consider several different weather-related factors together before you can decide (visibility, convection, ceiling, winds, and turbulence). The exact way that you combine them -- and the conclusion you come up with -- may be different for VFR, but it's the same kind of thing. Contrasting to the IFR decision making, where the exact nature of the forecast, predicted thunderstorms, existing conditions, air stability and the like are all important, when flying VFR all that's really important is that you can see well enough to maintain a wide berth from any existing thunderstorms and to know when they block your path of flight completely (i.e. there's no detour to take you around). It's much more cut and dried than for IFR flight. Hmm. What about when the forecast says good visibility, but the dewpoint spread in the METARs along the way suggests that the ceiling is going to come down hard? Is the morning lake fog going to stay over your destination airport longer than expected, given the prevailing winds? What about flying in light drizzle, studying the forecast to assure yourself that the temperature at your altitude will be far enough above freezing (and will those large droplets be supercooled or not?). It seems that there's a lot to worry about for VFR pilots as well. All the best, David |
#55
et.cable.rogers.com... [...] It seems that there's a lot to worry about for VFR pilots as well. I never said there wasn't, and I feel I made it perfectly clear that I was simplifying both the VFR and IFR cases for the sake of illustration. I don't mind when someone just disagrees with my subjective views, or is having a hard time with the methods I might use to convey my point (after all, one needs to communicate the point, even if it's the correct one). But when someone simply ignores what I've already said in an attempt to rebut what I've said, I fail to see the point in the discussion at that point. There's no hope for productive interaction. Pete |
#56
#57
Nathan Young wrote:
Having said that, I have had my IR for about 2.5 years (10yrs flying) and find it extremely valuable. Realistically, in a non-deiced single, it only adds a few extra flights each year that would otherwise have been no-go situations. That will depend, obviously, on where you live and whether you're willing to scud-run at 1,000 ft AGL or lower in MVFR, like the old-timers do (the ones who are still alive, anyway). An IR is probably not that useful out in big sky country, but where I fly (central Canada and NE U.S.), it figures into more than half of my longer cross-country trips and has saved me a couple of cancelled trips and several nights' hotel accommodation in the first ten months. Typically, I need only to climb a few thousand feet through a low overcast or broken stratus or stratocumulus layer, but sometimes I end up doing an entire flight in IMC. Only occasionally do I end up with a low approach at my destination. However, I find a huge benefit in the comfort factor added to VFR flight. Not having to worry about getting stuck on top, or worrying about lowering cloud decks forcing scud running is great. Agreed. All the best, David |
#58
news Nathan Young wrote: Having said that, I have had my IR for about 2.5 years (10yrs flying) and find it extremely valuable. Realistically, in a non-deiced single, it only adds a few extra flights each year that would otherwise have been no-go situations. That will depend, obviously, on where you live and whether you're willing to scud-run at 1,000 ft AGL or lower in MVFR, like the old-timers do (the ones who are still alive, anyway). An IR is probably not that useful out in big sky country, but where I fly (central Canada and NE U.S.), it figures into more than half of my longer cross-country trips and has saved me a couple of cancelled trips and several nights' hotel accommodation in the first ten months. Typically, I need only to climb a few thousand feet through a low overcast or broken stratus or stratocumulus layer, but sometimes I end up doing an entire flight in IMC. Same here, flying in the NE. I make several flights a year that are partially or largely in IMC; a few VFR flights that would not have been comfortable without an IFR option if weather deteriorated; and occasionally a VFR flight with unexpected IMC at my destination, requiring a pop-up clearance to approach and land instead of aborting. Also, an instrument rating is required for Angel Flight missions (even flying VFR). I use Microsoft Flight Simulator to help maintain my proficiency. Four times a year (usually around April and October), I fly a few local approaches on a LIFR day to be sure my official currency does not lapse (much of our summer IMC is unflyable due to embedded CBs, and winter IMC is unflyable due to icing). That combination, plus my occasional IMC XCs, works well for me. I seldom need to practice with an instructor or safety pilot. --Gary |
#59
"Journeyman" wrote in message . .. In article . net, Mike Rapoport wrote: Point is, with more things to consider and the added utility of the instrument rating, the go/nogo decision isn't as simple in the general case. I would disagree. Having an instrument rating just moves the actual no-go point farther to the right. I don't see why the no-go decision would get harder. I understand your point, and I'm willing to agree to disagree. For me personally, I found that it wasn't just a matter of pushing the decision point. A VFR-only go/nogo decision was far more black and white than IFR. One data point. Others provide their own data. Put it another way, IFR gives you more options than VFR, but it also gives you more ways to get yourself into trouble. You you analyze that to get the added utility the instrument rating provides is up to you. I say more things to consider == more complex == harder. Morris I also agree to disagree. The difficulty of thedecision making process is an individual thing. My perspective is that things have to go "more wrong" to endanger an IFR flight than a VFR one. The occurance of weather than can endanger an IFR flight in a light GA single is rarer than the reduced visibility that endangers a VFR flight. Just my opinion. Mike MU-2 |
Similar Threads | ||||
Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 02:16 PM |
Get your Glider Rating - Texas | Burt Compton | Aviation Marketplace | 0 | December 1st 04 04:57 PM |
51st Fighter Wing betters rating to ‘excellent’ with inspection | Otis Willie | Military Aviation | 0 | February 20th 04 11:29 PM |
Enlisted pilots | John Randolph | Naval Aviation | 41 | July 21st 03 02:11 PM |
