Garmin 396 battery question
I bought a 396 at Osh this summer and the battery never shows more
than half charge on the meter. However, if I just let it run, it runs to its full time, so apparently the internal meter needs to be reset. Anybody know how to do that? Yep, I did read the manual, couldn't find anything. |
Might try Garmin support. They are usually helpful.
http://www.garmin.com/garmin/cms/sit...upportcontacts "Paul kgyy" wrote in message ps.com... I bought a 396 at Osh this summer and the battery never shows more than half charge on the meter. However, if I just let it run, it runs to its full time, so apparently the internal meter needs to be reset. Anybody know how to do that? Yep, I did read the manual, couldn't find anything. |
I found that I deep cycle the battery by running the gps until it
dies, then recharge, each recharge is a little better. After 3 cycles, it's now up to about 95%. It also helped to download new firmware from garmin. |
Paul kgyy wrote:
I found that I deep cycle the battery by running the gps until it dies, then recharge, each recharge is a little better. After 3 cycles, it's now up to about 95%. It also helped to download new firmware from garmin. Paul has the right idea. I know several people with the same problem. Originally, Garmin was sending them new batteries, but that didn't help. It's some kind of bug in the software. As you continue cycling the battery, the display should get a little better each time. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200711/1 |
Similar Threads | ||||
Garmin 396 battery question | Paul kgyy | Piloting | 2 | November 16th 07 05:13 PM |
Garmin 196 battery connection? | RNR[_2_] | Piloting | 8 | February 20th 07 07:05 PM |
Garmin 430 Memory Battery | smf | Owning | 2 | January 4th 07 11:56 AM |
Battery Question | mbremer216 | Owning | 7 | October 6th 06 10:16 PM |
Battery Question | [email protected] | Soaring | 19 | September 15th 05 01:38 AM |
