new SSA web site
On Tuesday, April 6, 2021 at 1:02:59 PM UTC-4, Dan Marotta wrote:
What Moshe said. ...And I haven't even looked at it (I'm afraid...) Dan 5J On 4/6/21 7:01 AM, Moshe Braner wrote: On 4/6/2021 1:18 AM, Eric Bick (DY) wrote: Try this: From the new SSA homepage, mouse over the "Membership" tab. This brings up three options and you want the "Members" Only Resources." Go down to "Member Services" and click on that. This will bring you to a page with "SSA Member Resources." Click on the "Log In" button. That brings you to a login page, for which you use your "old" login info. Login and you will be greeted by your name. Go to the "Home Page" and you will now be in the old SSA website links (the underlay to the new webpage) and will be able to find info you are familiar with across the board - the "old" racing menu, records, calendar, Johnson Report access, etc. As time goes on, the front page should eventually provide a smooth interface to all this. With newfangled web programming it may look different to different viewers, but I don't see a membership "tab". In the drop-down menu (the three lines icon in the upper right) there is a "membership" entry. If I click on it I get a page with nothing useful. If instead I click on the drop-down arrow on the right end of that "membership" line, I see "Members Only Resources". If I click on that, it drops down a submenu of three items: Soaring mag, member locator, and sailplane directory. I don't see "Member Services" anywhere. And in any case, why build a "new website" that is just an annoying overlay over the old website? If anybody's listening, here's what I'd like to see: * a "site map" page with links only (no "media") * one login that gets you to *everything* * an option to "remember me" so you don't have to login every time * let me choose a short password I can remember * no "Captcha" I did the following: Go to https://members.ssa.org/login.asp. This asks for member ID and password. My information is the same as it has been for years. ID is my membership number and then my old password. This gets to SSA Member Resources. Select My Home Page That gets to much of the original SSA home page. Not all the links are there, but the ones important to me, and contest pilots, are all there and functional. Some things have not worked. When I have found glitches I have advised Frank Whiteley. He has been very responsive in trying to get them resolved. When a few of us were consulted last Fall we advised not to mess with the stuff deeper in the site that works because that all is very involved and no doubt beyond what the web site developer consultant will be able to do. My advice was to get the new face working with absolutely the least effect on the underlying functions as possible. It appears that the current situation does the latter. FWIW UH |
new SSA web site
On 4/6/2021 2:19 PM, Hank Nixon wrote:
On Tuesday, April 6, 2021 at 1:02:59 PM UTC-4, Dan Marotta wrote: What Moshe said. ...And I haven't even looked at it (I'm afraid...) Dan 5J On 4/6/21 7:01 AM, Moshe Braner wrote: On 4/6/2021 1:18 AM, Eric Bick (DY) wrote: Try this: From the new SSA homepage, mouse over the "Membership" tab. This brings up three options and you want the "Members" Only Resources." Go down to "Member Services" and click on that. This will bring you to a page with "SSA Member Resources." Click on the "Log In" button. That brings you to a login page, for which you use your "old" login info. Login and you will be greeted by your name. Go to the "Home Page" and you will now be in the old SSA website links (the underlay to the new webpage) and will be able to find info you are familiar with across the board - the "old" racing menu, records, calendar, Johnson Report access, etc. As time goes on, the front page should eventually provide a smooth interface to all this. With newfangled web programming it may look different to different viewers, but I don't see a membership "tab". In the drop-down menu (the three lines icon in the upper right) there is a "membership" entry. If I click on it I get a page with nothing useful. If instead I click on the drop-down arrow on the right end of that "membership" line, I see "Members Only Resources". If I click on that, it drops down a submenu of three items: Soaring mag, member locator, and sailplane directory. I don't see "Member Services" anywhere. And in any case, why build a "new website" that is just an annoying overlay over the old website? If anybody's listening, here's what I'd like to see: * a "site map" page with links only (no "media") * one login that gets you to *everything* * an option to "remember me" so you don't have to login every time * let me choose a short password I can remember * no "Captcha" I did the following: Go to https://members.ssa.org/login.asp. This asks for member ID and password. My information is the same as it has been for years. ID is my membership number and then my old password. This gets to SSA Member Resources. Select My Home Page That gets to much of the original SSA home page. Not all the links are there, but the ones important to me, and contest pilots, are all there and functional. Some things have not worked. When I have found glitches I have advised Frank Whiteley. He has been very responsive in trying to get them resolved. When a few of us were consulted last Fall we advised not to mess with the stuff deeper in the site that works because that all is very involved and no doubt beyond what the web site developer consultant will be able to do. My advice was to get the new face working with absolutely the least effect on the underlying functions as possible. It appears that the current situation does the latter. FWIW UH Thanks Hank. That does work for me. I've now bookmarked that login page, and also this one in case it remembers my login: https://members.ssa.org/MyHome.asp |
new SSA web site
What Hank and others have said about the members.ssa.org site being a "fallback" option to get to the old site systems is mostly true.
However, the situation is _RIPE_ for confusion because the New website shows an Events Calendar and a Racing Calendar - but the information on those was just copied from the old site at a point in time. It is NOT updating as people change information on the members.ssa.org website. This means that over time the information on www.ssa.org and members.ssa.org is going to drift out of sync (it already has done so for some events). So visitor "A" will look at an event on the new calendar and visitor "B" will look at an event on the old calendar, and wind up with different information! As I have said befo I am sure that there was the best of intentions; but this is an absolute mess. Its not about being afraid of change or not liking the new look & feel. Its about the management of the project, the systems, and thinking through how these new systems will actually *work* and be interacted-with by the Membership and the Public. --Noel |
new SSA web site
On 4/6/2021 3:13 PM, Moshe Braner wrote:
On 4/6/2021 2:19 PM, Hank Nixon wrote: On Tuesday, April 6, 2021 at 1:02:59 PM UTC-4, Dan Marotta wrote: What Moshe said. ...And I haven't even looked at it (I'm afraid...) Dan 5J On 4/6/21 7:01 AM, Moshe Braner wrote: On 4/6/2021 1:18 AM, Eric Bick (DY) wrote: Try this: Â*From the new SSA homepage, mouse over the "Membership" tab. This brings up three options and you want the "Members" Only Resources." Go down to "Member Services" and click on that. This will bring you to a page with "SSA Member Resources." Click on the "Log In" button. That brings you to a login page, for which you use your "old" login info. Login and you will be greeted by your name. Go to the "Home Page" and you will now be in the old SSA website links (the underlay to the new webpage) and will be able to find info you are familiar with across the board - the "old" racing menu, records, calendar, Johnson Report access, etc. As time goes on, the front page should eventually provide a smooth interface to all this. With newfangled web programming it may look different to different viewers, but I don't see a membership "tab". In the drop-down menu (the three lines icon in the upper right) there is a "membership" entry. If I click on it I get a page with nothing useful. If instead I click on the drop-down arrow on the right end of that "membership" line, I see "Members Only Resources". If I click on that, it drops down a submenu of three items: Soaring mag, member locator, and sailplane directory. I don't see "Member Services" anywhere. And in any case, why build a "new website" that is just an annoying overlay over the old website? If anybody's listening, here's what I'd like to see: * a "site map" page with links only (no "media") * one login that gets you to *everything* * an option to "remember me" so you don't have to login every time * let me choose a short password I can remember * no "Captcha" I did the following: Go to https://members.ssa.org/login.asp. This asks for member ID and password.Â* My information is the same as it has been for years. ID is my membership number and then my old password. This gets to SSA Member Resources. Select My Home Page That gets to much of the original SSA home page. Not all the links are there, but the ones important to me, and contest pilots, are all there and functional. Some things have not worked. When I have found glitches I have advised Frank Whiteley. He has been very responsive in trying to get them resolved. When a few of us were consulted last Fall we advised not to mess with the stuff deeper in the site that works because that all is very involved and no doubt beyond what the web site developer consultant will be able to do. My advice was to get the new face working with absolutely the least effect on the underlying functions as possible. It appears that the current situation does the latter. FWIW UH Thanks Hank.Â* That does work for me.Â* I've now bookmarked that login page, and also this one in case it remembers my login: https://members.ssa.org/MyHome.asp Well apparently it does NOT remember my login. Even though this is the "old web site" section, and the real old web site did remember my login. So bookmark the login page UH pointed to. At least my browser remembers my username and password for that login page. And yes "member locator" is under "News", after you go to "my home page". As are "sailplane locator" and "webinars"... |
new SSA web site
WOW!!!
I just looked at ssa.org and my head is spinning! I guess you gotta be a teenager with a cell phone grafted to your arm to appreciate that. I tried "Member Locator" under "News" and didn't find it. I finally found the member locator by starting at "members.ssa.org" then "My Home Page" then "News" My original password worked for that. Dan 5J On 4/7/21 8:47 AM, Moshe Braner wrote: On 4/6/2021 3:13 PM, Moshe Braner wrote: On 4/6/2021 2:19 PM, Hank Nixon wrote: On Tuesday, April 6, 2021 at 1:02:59 PM UTC-4, Dan Marotta wrote: What Moshe said. ...And I haven't even looked at it (I'm afraid...) Dan 5J On 4/6/21 7:01 AM, Moshe Braner wrote: On 4/6/2021 1:18 AM, Eric Bick (DY) wrote: Try this: Â*From the new SSA homepage, mouse over the "Membership" tab. This brings up three options and you want the "Members" Only Resources." Go down to "Member Services" and click on that. This will bring you to a page with "SSA Member Resources." Click on the "Log In" button. That brings you to a login page, for which you use your "old" login info. Login and you will be greeted by your name. Go to the "Home Page" and you will now be in the old SSA website links (the underlay to the new webpage) and will be able to find info you are familiar with across the board - the "old" racing menu, records, calendar, Johnson Report access, etc. As time goes on, the front page should eventually provide a smooth interface to all this. With newfangled web programming it may look different to different viewers, but I don't see a membership "tab". In the drop-down menu (the three lines icon in the upper right) there is a "membership" entry. If I click on it I get a page with nothing useful. If instead I click on the drop-down arrow on the right end of that "membership" line, I see "Members Only Resources". If I click on that, it drops down a submenu of three items: Soaring mag, member locator, and sailplane directory. I don't see "Member Services" anywhere. And in any case, why build a "new website" that is just an annoying overlay over the old website? If anybody's listening, here's what I'd like to see: * a "site map" page with links only (no "media") * one login that gets you to *everything* * an option to "remember me" so you don't have to login every time * let me choose a short password I can remember * no "Captcha" I did the following: Go to https://members.ssa.org/login.asp. This asks for member ID and password.Â* My information is the same as it has been for years. ID is my membership number and then my old password. This gets to SSA Member Resources. Select My Home Page That gets to much of the original SSA home page. Not all the links are there, but the ones important to me, and contest pilots, are all there and functional. Some things have not worked. When I have found glitches I have advised Frank Whiteley. He has been very responsive in trying to get them resolved. When a few of us were consulted last Fall we advised not to mess with the stuff deeper in the site that works because that all is very involved and no doubt beyond what the web site developer consultant will be able to do. My advice was to get the new face working with absolutely the least effect on the underlying functions as possible. It appears that the current situation does the latter. FWIW UH Thanks Hank.Â* That does work for me.Â* I've now bookmarked that login page, and also this one in case it remembers my login: https://members.ssa.org/MyHome.asp Well apparently it does NOT remember my login.Â* Even though this is the "old web site" section, and the real old web site did remember my login. Â*So bookmark the login page UH pointed to.Â* At least my browser remembers my username and password for that login page. And yes "member locator" is under "News", after you go to "my home page".Â* As are "sailplane locator" and "webinars"... |
Similar Threads | ||||
SSA web site | Roger | Soaring | 15 | April 3rd 05 05:47 PM |
EAA site down? | Jay Honeck | Piloting | 5 | March 7th 05 05:12 AM |
new site for creating project log and web site | Rob | Home Built | 2 | November 23rd 04 06:21 PM |
See My Site | Jürgen Exner | Simulators | 0 | January 5th 04 12:37 AM |
site | FBI © 2003 | Aviation Marketplace | 0 | July 7th 03 11:47 AM |
