Cambridge data port pins
On Apr 6, 9:33*am, "Tim Mara" wrote:
there is a pin-out diagram and kit for making your own cable on my website pagehttp://www.wingsandwheels.com/page11.htm It turned out that my problem was not the cables, or the PDA, or the 302. Just another one of those inexplicable incompatibilities of the Cambridge PDA utility. Attempting to download either of my flights from April 5 will cause the utility to exit and lockup the 302 so it does not transmit GPS data. Downloading any other flights stored in the 302 works just fine. Cycling 302 power restores normal operation as long as those 2 flights are not selected for download. Same effect seen with 2 different PDAs and 2 different cables, and is repeatable but not 100%. I did get lucky, but only once, and was able to transfer the flight logs. Andy |
Similar Threads | ||||
On the job with a port trucker: Port truckers like Marvin Palacios are the tiniest players in a prosperous global transport chain. But while big companies cash in, drivers barely make | Goteborgbank | Naval Aviation | 1 | October 13th 07 02:44 PM |
Cambridge 302A Data integrity. | Bob | Soaring | 4 | June 6th 07 02:04 PM |
Cambridge 302 -or- Borgelt B50 plus data logger | Romeo Delta | Soaring | 25 | May 30th 04 09:50 AM |
