grob main wheel and brake disk
Old July 17th 18, 04:38 PM posted to rec.aviation.soaring
Scott Williams
Default grob main wheel and brake disk
does anyone know the Parker/Cleveland part number for the brake Disk
used on a Grob Twin II fixed gear which used a Cleveland caliper? Glider made about 1981.
I'm aware of the Dot 3/4 compatible O-ring used in the caliper.
Thanks,
Scott
Old July 17th 18, 06:48 PM posted to rec.aviation.soaring
I had ours off of the club twin II recently and took a photo of the data plate. Here is the info on ours -
Model - 40-97A
Size. - 6.00 - 6
Static rating 2500 ( I assume this is pounds!)
Wgt. 5.8. ( again, assume pounds)
On the backside of the disk there are numbers following numbers stamped into it -- 26A 233
Ours accepts the 6.00 x 6 tire.
Hope,this helps, Mark Guay
Old July 17th 18, 07:18 PM posted to rec.aviation.soaring
My bad - numbers off of the data plate refer to the wheel hub. The 26A 233 number were stamped into the bachdide of the brake disk/rotor and the only identifying information on it.
Old July 17th 18, 09:15 PM posted to rec.aviation.soaring
Scott Williams
Thanks,
Scott
after a couple hours on the computer, I found a listing on an archived Cleveland
application chart, seems to call out;
disk, #164-02601
caliper, #30-63A, But the O-rings have to be changed out to dot 3-4 compatible rings.
linings#066-10500
wheel, #40-97A
thanks,
Scott
Old July 18th 18, 02:14 PM posted to rec.aviation.soaring
Scott Williams
Thanks,
Scott
Further a Cleveland/parker part # for a chrome disc is 126-12601
Old July 20th 18, 06:36 PM posted to rec.aviation.soaring
Scott Williams
Thanks,
Scott
Even further,
you need an EPDM #224 o ring, for dot 3-4 compatibility, hardness shore 70
and the torque plate number might be Cleveland 075-03700
Old July 20th 18, 07:49 PM posted to rec.aviation.soaring
OK, my bad, looking to learn......what was the original hydraulic system? If mineral oil, I can see the O-ring swap, otherwise, I "believe" ANY DOT fluid works in ANY system (other than DOT 5 which REALLY SUCKS WATER OUT OF THE AIR).
So, you can run ANY DOT brake fluid in any DOT system, DOT 5 just means a lot more fluid changes.
So, DOT 1-4 and DOT 5.1 are all compatible.
Again, just asking for my edumafication as well as others (misspelling intentional).
Old July 20th 18, 08:38 PM posted to rec.aviation.soaring
On Friday, July 20, 2018 at 2:49:20 PM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote:
Are you sure about this? Sounds like you are, but DOT 5 brake
fluid is silicone based, isn't it? Hydrophobic, as I read it.
Silicone brake fluid is a favorite with some antique car owners,
since it doesn't absorb water, which rusts the interior of the
brake system. I've got it in my old cars. It has other problems,
like being harder to bleed, though.
Or I could be completely wrong again.
Jim Beckman
Old July 20th 18, 09:22 PM posted to rec.aviation.soaring
Scott Williams
Thanks,
Scott
Well,
to the best of my knowledge, and the Grob 103 twin II manual, and service bulletin OSB 315-17, .
the master cylinder was a modified Magura motorcycle part, which might have been original equipment on BMWs, maybe a R100? which uses dot 3 fluid.
The original equipment caliper is a Cleveland/Parker Hannifin 30-63A, which has a Buna-N O ring( MS28775-224) for use with petroleum based aircraft hydraulic fluid,
I think it was easier and cheaper to change the caliper O ring than to change the master cylinder seals.
The "O ring swap" I mentioned was intended to ensure caliper O ring compatibility with the Brake fluid indicated in the flight manual.( dot 3)
If someone simply replaced either the caliper or just the O ring with the Cleveland called out part number, this would result in the Cleveland O ring swelling over time. That is something you don't want in a caliper.
The ID label on our Grob 103 caliper should be labeled "DOT 3" but is not (Yet).
Larry Suter, on rec aviation Jan. 6th 2015 started a thread that covered it better than I.
If I'm incorrect, please post.
Thanks,
Scott
Old July 20th 18, 09:55 PM posted to rec.aviation.soaring
Ummmm....yes, I am very happy with my post.
Pretty much ANY DOT fluid is cross compatible EXCEPT DOT 5.
DOT 5 "will work", but it is even MORE water hungry than others. I do not believe it is a seal issue, it is water absorption issue. Thus, race cars is fine, other uses, sucks.
Now, mineral based fluids vs. DOT fluids is a different matter. Thus my question.
Oh, and to accentuate this, if you have an old system that uses DOT 1, using DOT 1-4 AND 5.1 is fine.
Yes, I made a bold statement, I will do my best to provide GOOD relevant links to prove, not just me stating it. Say, within 24hrs?
WTB - used Cleveland 40-78B main wheel Roy B. Soaring 1 February 19th 18 08:25 PM
hydraulic disk brake upgrade shkdriver Soaring 2 June 27th 13 05:41 PM
ASW-24 Main Wheel Removal Lauren Rezac Soaring 5 March 19th 12 04:20 PM
Tost 5“Penta disk brake wheel Mod for Duo Discus Mike I Green Soaring 0 February 6th 12 09:38 PM
Tost Disk Brake rebuild? Paul Cordell Soaring 10 April 17th 08 07:20 AM
