Garmin 90 Database Updates Discontinued
Old August 15th 03, 12:23 PM
CryptWolf
John Galban wrote in message
om...
Looks to me like the database has just outgrown the GPS-90s
available capacity. That strikes me as being more likely than a
sinister plot by Garmin.
As an old computer hacker, (25+ years) I have to wonder
why no one is looking into removing parts of the database that
aren't needed. For example, someone who does mostly local flying
might not need much more coverage than a few states.
Along these lines, what program loads the database, what format
is the database in, any special hardware needed, and where can you
get a current database that might be converted? There must be a
number of programmers around who are also pilots besides myself.
Why couldn't a program be written to convert a current database
so that the GPS-90s could be used a while longer? I'd bet quite a few
would like to have a free program that simply converted another
database into the correct format. What about using an FAA database
and converting it directly?
If this GPS can be updated with a freeware program, then what
about other databases? I suspect several other GPS units will
become obsolete because of memory restrictions. Also note that
it will be unlikely that all GPS brands will be immune. Your brand-Y
unit may be ok today while falling into the same boat as brand-X
next year.
Oh, before you get to deep into what a hacker is, try to forget the
media hyped version. There is usually 3 definitions of hacker.
Only one is a criminal and one is a bad programmer. I'll let you
figure out what the third one is.
Old August 16th 03, 03:02 AM
Greg Kainz
It sounds like that's already happened. I got an email from someone
who has written such a program. I'm probably going to check this
route out, as Garmin says I can't buy a database from them for the
GPS 90; even an old, out of date database...
Greg
"CryptWolf" wrote in message
s.com...
om...
next year.
George Graham ----Garmin 95XL database Bill Zaleski General Aviation 2 April 28th 11 09:14 PM
GNS480 database updates Dave Butler Instrument Flight Rules 7 November 12th 04 02:35 AM
Multifunction display database updates Charles Talleyrand Owning 2 January 27th 04 04:35 AM
Garmin GPS-90 moving map Aviation GPS with latest Jeppessen database update installed Jerry Bransford Aviation Marketplace 5 October 2nd 03 03:31 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 02:04 AM
